Need help fast!!! Can't get shaft drive swing arm off.
kiwi kdx
#1 PostAuthor: kiwi kdx » Tue May 14, 2013 11:40 am
Hey guys does anyone know how to get the 2 pins that hold a shaft drive swingarm out?
I have the 3 bolt caps off and can see the pins I had assumed they would have a thread in them
So I could screw something in and pull them out, but nothing???????
I need this off ASAP as someone is coming to pick it up in 2 days.
Jay1969
Re: Need help fast!!! Can't get shaft drive swing arm off.
#2 PostAuthor: Jay1969 » Tue May 14, 2013 3:13 pm
kiwi kdx wrote:Hey guys does anyone know how to get the 2 pins that hold a shaft drive swingarm out?
Try a YouTube search, maybe a tutorial :)
oldzed
#3 PostAuthor: oldzed » Tue May 14, 2013 6:18 pm
If its a z1000 shaft then there should be an allen key fitting in the middle of the pin.
Leave the 3 bolts in and the pin will unscrew using the allen key fitting.
If there is a round hole in the middle they have been stripped like mine.
I had to hammer a torq type bit in to remove them.
member number 0664
Who can catch a Kawasaki?
A police helicopter
#4 PostAuthor: z1bman » Tue May 14, 2013 8:11 pm
IF IT HAS NOT GOT A THREAD IN THE CENTRE OF THE BUSH YOU WILL HAVE TO DRILL + TAP A THREAD TO 6MM TO REMOVE IT . THE Z1300 HAS A 6MM THREAD IN THE CENTRE + IS A VERY SIMILAR BUSH BUT IF IT HAS NEVER BEEN REMOVED YOU WILL NEED A PULLER AFTER YOU HAVE PUT A THREAD IN THE BUSH AS IT IS LIKELY TO BE SEIZED
Users browsing this forum: Bing [Bot] and 161 guests
