Anyone Familiar With Rickman Kawasakis?
Rickmanrider
#1 PostAuthor: Rickmanrider » Wed May 15, 2013 6:10 pm
As a newbie to the forum, I bought a Rickman Zed Thou project minus wheels, and have been trying to fit std Kawa mag wheels, as definitely fitted to the Rickman Z1000 I used to have. LOTS of machining/head scratching fun have ensued...
First question, is there any dimensional difference between Z650 and Z1000 18" back wheels? Im told Ive got a Z650 not Z1000 rear wheel off the eBay of Plenty. They look pretty similar. Im wondering if Im making work for myself if there are differences, trying to get the alignments right
ALso, it would seem that for whatever reason, back in the day Rickman cast up a dished alloy disc-carrier of their own devising for std Kawa mag-wheels as well as a Rickman branded Lockheed caliper carrier. Being reunited with my old Rickman, I can see that there are alloy Rickman parts on the back. Im wondering if that was key to wheel & chain alignment. Id dearly love to buy either/both if any kind soul has one surplus to requirements!
At the moment Im trying to take a speedo drive off my Kawa Z mag front wheel, whatever that is from, which definitely has provision for a speedo-drive as std, but Ive have had to machine the speedo-drive down as narrow as I dare, to get it to fit between the (Betor) forks and Rickman yokes and still keep the wheel central, yet the bike as I got it, came with a speedo cable to the (missing) back wheel. What Kawa wheel had a rear-wheel speedo drive?
ANy help appreciated from them what knows
Simon
Crofty
#2 PostAuthor: Crofty » Wed May 15, 2013 6:14 pm
Welcome to the site, I used to have a Rickman H**** and that had the betor forks and the speedo came off the back wheel too.
Might of been a Rickman mod.
Big Fluff might be able to help and there are others on the site with Rickmans
The Zedster
#3 PostAuthor: The Zedster » Thu May 16, 2013 6:10 am
Hi Simon welcome , i have a Rickman Kawasaki z1000, and the cb750 engined Rickman, both have the rear wheel speedo drive, and both have kawasaki wheels, cant help you with spare parts but might be able to measure some of my parts
i think rickman made a rear speedo drive plate for the kawasaki wheel which used the donor bikes speedo gear
pete
#4 PostAuthor: Pigford » Thu May 16, 2013 9:47 am
Hi Rickman Rider :wink:
Seems to be a few more Zeds coming out the woodwork in the SW quarter :P
Iain marshall
#5 PostAuthor: Iain marshall » Thu May 16, 2013 6:48 pm
Rickmanrider, send me a pm with your contact number (landline) and I'll give you a call about the wheel set up on the Rickman
stevemc
#6 PostAuthor: stevemc » Thu May 16, 2013 10:06 pm
mine has Z900 front hub, speedo drive was reduced both sides to get to work, first time i only reduced the outside but was too mutch and cracked when spindle was tighten up, also used z650 discs (smaller diameter) with 5 mm spacer, hope this helps
#7 PostAuthor: Rich » Fri May 17, 2013 4:56 pm
Smiths drive for the rear,
Veglia for the front, only problem with Veglia is that the cable exits at the front of the fork.
can't remember what ratios though, you,d have to work it out
Big Fluff
#8 PostAuthor: Big Fluff » Sun May 19, 2013 4:06 pm
I'm pretty sure all rear speedo drives are H**** cb750, regardless of engine fitment.
Rickmanrider
Zed wheels on a Rickman
#9 PostAuthor: Rickmanrider » Mon May 20, 2013 11:02 am
Cheers for this info - a great start! Grateful for any measurements
Users browsing this forum: No registered users and 143 guests
