#241 PostAuthor: zed1015 » Fri May 24, 2013 9:02 pm
On to the downpipes tonight.
Bends out of the head are matched to the ports at 35mm and the bottom bends to the collector are 38mm so time to knock up some tapered headers
A simple notch to the required length was closed up with some hose clips then tacked in place before removing the clips and welded in full
Middle pipes slotted on and lower bends offered up
A bit of adjustment and they are ready for welding.
Some alloy angle held on with hose clips keeps every thing tight and in line and leaves enough of a gap so i can get a couple of tack welds on.
Keefleaf
#242 PostAuthor: Keefleaf » Sat May 25, 2013 1:17 pm
Your making a lot of people Lime Green with envy :lol:
Re;carbs. Will you be using the smoothbores slides as made by Z1 Enterprises?
#243 PostAuthor: zed1015 » Sat May 25, 2013 8:37 pm
Keefleaf wrote:Your making a lot of people Lime Green with envy :lol:
Haven't seen those but will be using the slides i have anyhow as they will work as good as any.
#244 PostAuthor: zed1015 » Sat May 25, 2013 9:21 pm
Got the mid pipes welded this morning and then tackled the outers
These are a bit trickier as they have to snake round the mid pipes and still end up the same length as the others at the collecter.
After lots of adjustment it misses everything so gets a visit from mister welding torch after which i have to make a mirror image for the other side
Time flies when you're having fun and todays 10 hours in the shed gets me this :D
Managed to get all the pipes the same length give or take a millimeter.
Just need to make some spring tags to pull it all together and then on the the link pipe and silencer.
Keefleaf
#245 PostAuthor: Keefleaf » Sat May 25, 2013 11:26 pm
:D KILLER :D
#246 PostAuthor: Pigford » Sun May 26, 2013 7:07 am
You is some sort of genius Rob :wink:
Royalratch
#247 PostAuthor: Royalratch » Sun May 26, 2013 8:33 am
Seriously bad-ass Rob.
PJ
#248 PostAuthor: PJ » Sun May 26, 2013 8:45 am
Brilliant
z1bnackerkwacker
#249 PostAuthor: z1bnackerkwacker » Sun May 26, 2013 9:46 am
Almost think it's perfect.
Gonna throw a spanner in works now.
Don't like the rear lower of frame where it's been chopped.
Maybe it'll be hidden by exhaust ?.....
:roll:
#250 PostAuthor: zed1015 » Thu May 30, 2013 3:24 pm
Spring tags and springs on
Mid pipe done
And the beginings of a silencer
garyd
#251 PostAuthor: garyd » Thu May 30, 2013 6:20 pm
Leave the pipe like that...start a new trend :D
Is Vic There
#252 PostAuthor: Is Vic There » Fri May 31, 2013 12:32 am
Your getting close to hero status :D
#253 PostAuthor: zed1015 » Fri May 31, 2013 9:28 am
Is Vic There wrote:Your getting close to hero status :D
Better start wearing my undies outside of my pants then :lol:
garyd
#254 PostAuthor: garyd » Fri May 31, 2013 10:37 am
Don't forget to wash them first :git
Mr Puffin
#255 PostAuthor: Mr Puffin » Fri May 31, 2013 12:38 pm
Awesome Zed :twisted:
