Exhaust smoke after throttle shutdown
- z1000puddin
Guys,
I had a hundred or so miles on my 1075 zed. yesterday.
My mate following noticed that there was smoke coming from the exhaust when the throttle was shut-down. Noticeably when it was getting a good thrash.
The bike has new MTC piston & rings
28mm carbs with 112.5 mains & 17.5 pilots.
Open ally trumpets
Intend getting it dynod, but I am concerned about the smoke - Should this happen on a rebuilt motor ??
Or should I carry out a compression test. ?
The bike starts & idles well, pulls well although it may need a jet up one or two.
.The bike has done a couple of hundred running in miles.
Stu
Open ally trumpets
Stu
Zed til Dead
- z1000puddin
PaulMceleney
- Chunks
- z1000puddin
PaulMceleney
- Chunks
- z1000puddin
PaulMceleney
- Chunks
- z1000puddin
PaulMceleney
- Chunks
Charlie wrote:How much smoke and what colour is it ?
I would go back to this before deciding to play with carbs. Blue = Oil, Grey/White =Rich mixture which, looking at your plugs, I would say is not your problem.
I am not sure if leaking oils seal will show on a compression test? The blue smoke on over run is usually due to the increased vacuum when the throttle is shut off sucking oil passed leaky seals on the inlet side.
