Z1000 CLUTCH BASKET BROKEN SPRING SYMPTOM
z1000puddin
#1 PostAuthor: z1000puddin » Mon Jun 03, 2013 5:57 pm
Guyz,
What would the symptom of a broken clutch basket spring be ??
stu:
Zed til Dead
hillbilly
#2 PostAuthor: hillbilly » Mon Jun 03, 2013 6:08 pm
is it the one I give you,if so.sorry. :wink:
#3 PostAuthor: chrisu » Mon Jun 03, 2013 6:43 pm
if you need another one let me know
z1000puddin
#4 PostAuthor: z1000puddin » Mon Jun 03, 2013 9:59 pm
Brent,
No its not that one mate.The one I got from you is in good order.
Its the one that was fitted in my green zed.
I am getting a weird grinding/whizzing noise when moving off in first gear.which disappears once I am rolling.
The springs looked okay when building the motor & as the engine is run in now, it is getting a bit more of right handful.
I was planning on having it on the dyno to get the carbs spot on (with probably larger main jets)
There is no other symptoms, e.g. clutch slip or drag.
I suppose I am hoping that it is something that wont require splitting the cases
:cry:
Zed til Dead
#5 PostAuthor: Pigford » Tue Jun 04, 2013 10:14 am
You can sometimes get a bit of noise & juddering if pulling away slow & careful. Give it a bit of welly and it gets less :!:
Engine strip to get a clutch basket out :??
RGH
#6 PostAuthor: RGH » Tue Jun 04, 2013 1:45 pm
If you (or previous owner) have mistakenly filled with synthetic oil- especially ester based- will get that buzzing/whirling/grinding noise on launch, grabs releases grabs, pay to whip out clutch pack (incase still traces synthetic oil hanging around) and clean up with kero, soaked in mineral oil for few hours refit your away.
Recently a local RE5 had same prob, he spoke too previous owner, bingo used synthetic oil.
#7 PostAuthor: chrisu » Tue Jun 04, 2013 4:54 pm
Pigford wrote:You can sometimes get a bit of noise & juddering if pulling away slow & careful. Give it a bit of welly and it gets less :!:
no
z1000puddin
#8 PostAuthor: z1000puddin » Tue Jun 04, 2013 8:51 pm
Thanks guys,
I will try the clutch plates out first & have a look at the basket when I am in there.
Not at the mo though as the weather is too nice
Will post once I have a look
Stu
Zed til Dead
Garn 1
#9 PostAuthor: Garn 1 » Wed Jun 05, 2013 2:02 am
From memory, I don't think those radial spring are exposed when you remove the plates. I have however, seen the springs wearing thru the plate. Hopefully it's not that! They do go for years with a broken radial spring or two.
#10 PostAuthor: Pigford » Wed Jun 05, 2013 6:35 am
no
No wot :roll:
#11 PostAuthor: chrisu » Wed Jun 05, 2013 12:01 pm
no you don't need to split the cases to get the clutch basket off
z1000puddin
#12 PostAuthor: z1000puddin » Wed Jun 05, 2013 9:02 pm
Chris,
I though you had to split in order to get the basket off ??
Please do tell :?:
Stu
Zed til Dead
#13 PostAuthor: chrisu » Wed Jun 05, 2013 9:19 pm
My bad
You can take the basket off the spline but you can't take it out of the casing without splitting the cases
Oops
z1000puddin
#14 PostAuthor: z1000puddin » Wed Jun 05, 2013 9:47 pm
:D
No worries - I thought you had a cunning plan :D
Zed til Dead
#15 PostAuthor: Pigford » Thu Jun 06, 2013 11:15 am
chrisu wrote:My bad
Oops
APOLOGY ACCEPTED Mr UNDERHILL :wink:
Users browsing this forum: Bing [Bot] and 118 guests
