Hi I'm looking for z1000 rear wheel spacer the one that's located by the Cush drive
Many thanks
Spacer
Phil Denton engineering will make you one, but his turn around is not quick.
Collar which fits between Swing arm and sprocket carrier -
http://www.ebay.co.uk/itm/KAWASAKI-KZ10 ... 255b6d5369
Collar which fits within cush drive - between sprocket carrier and wheel hub.
http://www.ebay.co.uk/itm/NOS-Kawasaki- ... 257ce95286
COLLAR THAT FITS INTO OIL SEAL ON THE OUTSIDE OF THE SPROCKET HUB
http://www.ebay.co.uk/itm/KAWASAKI-Z100 ... 51ad879e50
malmojoe wrote:That's more collars than the Sweeny.
Too true matey.
