Drive chain lube
Drive chain lube
Any suggestions to what is the best chain lube these days with "non-throw" properties.
Regards
Steve
Regards
Steve
steve
I found this pretty good and it's on offer too at the mo which is a bonus
http://www.halfords.com/webapp/wcs/stor ... 66853#tab3
Garn 1 wrote:Guys, can both the above mentioned products deal with both O-ring & non 0-ring drive chains.
Holts Motorcycle Degreaser - 300ml Description
"High performance Holts Motorcycle Chain Lube is a particularly effective synthetic lubricant. With a unique anti-fling formula, Holts Motorcycle Chain Lube won't drip, instead providing first rate protection and performance to the modern drive chain.
Features and Benefits of Holts Motorcycle Chain Lube
■ Compatible with O ring seals for complete versatility
■ Lubricates and looks after motorbike chains for vastly improved riding""
- irhobotolo
Wurth High Perf Dry Chain Lube
This works well
http://www.wurth.co.uk/product/highperf ... ychainlube
PUM 451
I have also used Wurth dry non fling lube, and found it better than others I have tried. Can recommend it
- chrispyduck
Motul chain clean then Motul chain lube; ace!
http://compare.ebay.co.uk/like/40050944 ... 80&ff14=65
"Keep on Rockin'!"
