Carbs leaking petrol all over
Hi just got my bike out after been layer up for ten years. Started up but leaking petrol from the petrol pipe where they go into the carbs by the T piece. I'm not knowledgable enough to strip the carbs down so wondering how much it would cost to recondition and clean them up. I've taken the carbs off now!
- z1000puddin
After 10 years with petrol in the system,the petrol will have gone "bad".
The result will be a sticky "varnish" that will have built up inside the carbs, blocking the jets , needles etc.
Can be expensive having them cleaned by a third party e.g vapour or sonic cleaned - But def. worth it.
You can with minimal mechanical knowledge strip & clean them yourself.
Get a hold of a manual & read through the carb section.
Give it a try- it will save a couple of hundred pounds
stu
stu
Zed til Dead
As a temporary solution you could buy a carb 'repair' kit, which basically
includes all the seals and gaskets you need and new float valves in it,
they are inexpensive to buy from Z-Power https://www.z-power.co.uk/merchantmanag ... cts_id=148 at £17 for each carb
and will help you get on the road for summer (yeah what summer? lol)
until say winter, when you lay the bike up again, then get them vapor / sonic blasted like stu said...
P.S. you may even get a bit of discount with Z-Power if you're
a full paid up club member, but don't quote me on it, think it depends
on certain items.
on certain items.
Wow!
Those storage vacuum bags must work well then.
I've got an inflatable cocoon thing that I store my bike in over winter,
which requires a fan inside to keep it inflated, which means yeah, I can see
the bike is in a big clear plastic inflated bubble,
but it takes up a lot of room, so looks like one of them
vacuum bags will be adequate and space saving too.
You must be excited about your first ride around on it.
Good luck with the carbs
wilsonsjw11
Jay1969 wrote:Wow!Those storage vacuum bags must work well then.
Na you have a blow doll, tell the truth
Taffus wrote:Jay1969 wrote:Wow!Those storage vacuum bags must work well then.
Yep, she rides with me everywhere on my H-D.
Bike Cocoon
Seriously though, here is my Bike Cocoon when it is inflated
Re: Bike Cocoon
Jay1969 wrote:Seriously though, here is my Bike Cocoon when it is inflated
That's big enough to fit my arse in!
But seriously it looks full of shit
meant to say a highly desirable Harley Taffus wrote: That's big enough to fit my arse in!
meant to say a highly desirable Harley Jay1969 wrote:
Garn 1 wrote:NjW, like your Z1A! That has to be the neatest set of crash bars I've seen.
You can buy new tee-pieces in alloy, they have replaceable o-rings. The originals with their plastic bulge always fail. Could be a simple fix, particularly as it runs now.
Thanks. Where can you buy the T pices I've only seen the plastic ones.
Users browsing this forum: Google [Bot] and 36 guests
