Newz from the BuzzardWorkz
torque arm
Don't need a torque arm, the bracket arm has a slot machined into it and that engages with a spigot on the swinging arm which stops it from rotating when brake is applied. See first picture with wheel in it. Buzzard.
Every man should have a shed (for bikes obviously..)
Re: torque arm
buzzard wrote:Don't need a torque arm, the bracket arm has a slot machined into it and that engages with a spigot on the swinging arm which stops it from rotating when brake is applied. See first picture with wheel in it. Buzzard.
I didn't know you made stuff for customers Buzzard, I've sent you a PM
Re: torque arm
Got it. That is excellent, very inspiring cheers buzzard.
Users browsing this forum: Google [Bot] and 49 guests
