engine low speed "jerking"
RAYZ1
#1 PostAuthor: RAYZ1 » Tue Jul 09, 2013 10:45 pm
My z1B has develped a bad case of engine jerking at small throttle openings, say 2000rpm on a constant throttle opening, its perfect at highr speed, ie 3000rpm plus or under load. Its a bit like having kangeroo petrol if you know what I mean
before I start on the hunt for the issue - anybody had similar problems ?
Im going to check carb balnce and timing, I dont think the pilots are blocked as it accelerates and pulls well from low speed on 1/4 throttle, I suppose the pilot airway could be blocked.
When the bike was rebuilt, it would run down to 20mph in top and pull constant , that was 3 years ago
I bet its pilots but glad to hear any other suggestions
thanks
Ray
Jay1969
#2 PostAuthor: Jay1969 » Tue Jul 09, 2013 11:02 pm
Try a simple elimination process first, like petrol starvation: pipes from tank, spark plugs, ht leads, caps, then move on to carbs?
Users browsing this forum: No registered users and 91 guests
