Anyone know if Tarozzi do a fork brace that fits the Mark II ?
I've found the following Tarozzi part no.s:
23-0012 - Z1000 A1-A2
23-0014 - Z1R
Not sure what the difference between the above 2 would be?
Tarozzi Fork Brace for Z1000 Mark II
- Vendetta761
Vendetta761 wrote:Not trying to steal the thread but I am after a fork brace, Tarozzi,Telefix or Micron for an ST and I figure all the dims are the same as a Mk 2 and maybe an H or a J , would one fit all ?
Tarozzi list a different part no. for the ST (23-0011) - think the dia of the fork stanchions is possibly larger than the MK 2
- Vendetta761
I have a Mk 2 mudguard on one of my Zs but I never measured the forks, maybe I need to cross reference the manuals ?
1980 Z1000 E1- ST , 1980 Yamaha XT 250 3Y3 , 1979 Moto Guzzi G5 special , 2000 V11 special, 2009 XT660 X
Try Howard, he should be able to help...
Howard
www.discovolantemoto.co.uk
Cafe racer central!
www.widecase.com
Quality parts for Classic Ducatis
Howard
Cafe racer central!
www.widecase.com
"Keep on Rockin'!"
Tarozzi Fork Brace for Z1000MK11
Vendetta761 wrote::evil: Bugger and blast, why did they have to make everything on the ST slightly different from the Mk2 , its only a chain /shaft thing after all , is n't it?
Yep same as above but I've got 1000rx forklegs in mine which are the same diameter as our ST originals but it gives you another forkbrace which might fit, long time ago in Bradford a certain motorbike shop had an ST in, bent leggies (oops) the shop owner told the mechanic to fit some z1000j legs which were good BUT 2mm smaller so obviously clamped up tight the pinch gap was together but not safe so you may have already guessed out came the angle grinder gap restored butchery at its finest beware some of this lot may still be out there, be warned. I still want another Gpz11 B1/2 in my heart of hearts I'll build myself one then I'll know its right, jeepers just used all the stainless fasteners on the ST!!!
More Smiles Per Mile
- Vendetta761
mmm, ta for that, just had a look for a 1000RX brace on ebay and there are 2 but it looks like I would need a lot of other clamps made up for me to fit the brace on, still I am at work so have not looked too clearly. Have you got any pix of yours please?
