restoration of clocks
Can anyone recommend someone who can sort my clocks out. the faces have bubbled up and look real bad. Can you get overlays for them, this is my first Z1B restoration. Thanks for any help (phone numbers).
- Regular Poster
you can get reproduction speedo and tacho faces from berni at beezeees.com about ?30 each, alot cheaper than having the clocks refurbed, just fitted them to my z1b and they look the nuts! be carefull if doing it yourself as the needles are a pig to get off (i did mine by CAREFULLY levering them up with 2 electrical screwdrivers one on each side of the needle they are not glued just a tight push fit)
Davy Doherty wrote:Contact Chris Rivett on 01604455160 or 07917365060 he does a fantastic job and has done a few for the lads here..
Chris did the clocks on my A4 about 8 years ago and they still look good. He has done clocks for Paul Scanlon, who is FUSSY.
