Z900 A4 Carbs
bollypne
Z900 A4 Carbs
#1 PostAuthor: bollypne » Fri Sep 21, 2007 8:10 am
Hi All, i am just putting back together an A4 Z900, i have 2 sets of carbs but not sure which is correct. 1st set has 2 feeds for fuel and what seems to be a link pipe between the carbs, flexible fuel pipe. This pipe sits between 1&2 and 3&4. Cable link sits at top of carbs. Throttle stop above carbs.
The other set of carbs have 1 feed for fuel and what seem to be 2 breather pipes. Cable link differs from 1st set with 1 cable link further down between the carbs. Throttle stop is underneath.
I think both are 26mm carbs and look identical apart from bits above.
#2 PostAuthor: chrisu » Fri Sep 21, 2007 12:11 pm
the first set you describe matches the carbs on my A4.
hope this helps...............
others sound like Z1000 carbs
Surfdeneige
#3 PostAuthor: Surfdeneige » Fri Sep 21, 2007 4:00 pm
Someone will no doubt put me right but here is what I think..... Single feed is Z900 Z1/A/B. Z900A4 is twin feed as per Z1000A1/2.
A ken fit like!
000zeds
#4 PostAuthor: 000zeds » Fri Sep 21, 2007 4:38 pm
All Z1s / Z900s / Z1000A1s and early Z1000A2s have 2 petrol feed pipes. Later Z1000A2s and all Z1000MK2s have a Vacuum fuel tap and single petrol feed pipe of bigger bore.
Zeds-R-Us
Surfdeneige
#5 PostAuthor: Surfdeneige » Fri Sep 21, 2007 6:31 pm
I have a late z1000A2(a) and that is twin?!
A ken fit like!
000zeds
#6 PostAuthor: 000zeds » Fri Sep 21, 2007 10:08 pm
Maybe only some A2s have Vacuum and not later ? ? ? ? ? ?
Zeds-R-Us
