mikuni rs36
jovin04
mikuni rs36
#1 PostAuthor: jovin04 » Sun Jul 28, 2013 1:41 pm
Hi I have a set of Mikuni RS36 Flatslide carbs on my gpz1100 motor. It has been striped down after 300 miles with new Wiseco pistons etc it appears the bores have been washed out with fuel. Can anyone give any recommendation's for the carb settings.
I am currently using a 130 main jet in may be washing out on the pilot??
Many Thanks
#2 PostAuthor: Pigford » Sun Jul 28, 2013 2:23 pm
I run 130 mains with 17.5 pilots on me Z1000A2 - 1075 Wiseco, flowed head, std cams - RS36's :wink:
jovin04
Re-carbs
#3 PostAuthor: jovin04 » Sun Jul 28, 2013 6:47 pm
Hi there thanks for your help, that's the same set up I'm using so it shouldn't wash the bore??
Cheers Vince
Taffus
#4 PostAuthor: Taffus » Sun Jul 28, 2013 6:55 pm
pm London Calling " Jack" or Big Green Bus they have experience of the 1170's (as do a lot of others but these 2 I can remember!)
marve114
#5 PostAuthor: marve114 » Mon Jul 29, 2013 12:56 pm
Forgive me is im wrong but could it be float heights god knows what they are suppous to be on these 36mm mikuni's
im running same set up also so will be interested to see your findings
big green bus
#6 PostAuthor: big green bus » Mon Jul 29, 2013 5:05 pm
The floats should be around 17 mm. I had loads of probs with flooding and have been told the valve and seats could have been mismatched as there are two sizes. 130s are about right I had mine dyno'd so will check the needles etc for you.
marve114
#7 PostAuthor: marve114 » Mon Jul 29, 2013 5:21 pm
Checked mine has got 134's
17.5 pilot
Mixture 1 1/2 turns out
Needle clip 2nd from the top
But I've not run this properly yet
But will check the float heights
big green bus
#8 PostAuthor: big green bus » Mon Jul 29, 2013 8:44 pm
marve114 wrote:Checked mine has got 134's
17.5 pilot
. Looks like we are all around the same mark
