GPZ1100 Unitrack
snotie1965
GPZ1100 Unitrack
#1 PostAuthor: snotie1965 » Fri Aug 02, 2013 9:46 am
I have just got a s/hand tank in original red , but the front under side of the tank is very rusty ! both sides , is there anything i could use to seal it from the outside to stop it getting worse and to prevent any leaks ? it only has to be a temp fix until i can get it repaired properly and re-painted in the winter months ?
I was thinking something like a petrol re-sistant filler/mastic type stuff ??
#2 PostAuthor: z1bman » Fri Aug 02, 2013 10:32 am
IF IT IS JUST SURFACE CORROSION TRY THIS
http://www.ebay.co.uk/itm/JENOLITE-Rust ... 1c3412579a
snotie1965
#3 PostAuthor: snotie1965 » Fri Aug 02, 2013 11:58 am
I have just rubbed all the loose off and then wire brushed the area , and on close inspection it looks like it has almost gone through , so it will need some type of filler ?
#4 PostAuthor: z1bman » Fri Aug 02, 2013 12:07 pm
the best way is to get it lead loaded but this process would ruin the paint work + there are not many of these type of craftsmen left. you would need to find someone who does classic car restoration but this done properly would be better than any type of filler
give this company a call they might be able to help
http://isiscoachworks.com/index.php?opt ... &Itemid=66
http://www.ebay.co.uk/itm/Kawasaki-GPZ1 ... 51afccfec3
Users browsing this forum: No registered users and 143 guests
