How to find oil leak [I know me again]
zman
#1 PostAuthor: zman » Mon Aug 12, 2013 12:16 pm
you may already be bored with my help posts.
i need help in identifying source of oil.
No1 plug is black & sticky.I believe this to be oil not fuel as fuel would be black & dry.
The engine smokes the higther the revs.If it was valve stems it would smoke on closeing the throtel.So belive it must be rings.
Compression test results
1=150 2=165 3=170 4=170
If it was compression rings wouldn't it be pressurising the crank and blowing oil past the breather :?:
Could it just be oil ring :?:
How can i be sure :?:
keep thoses wheels turning
Taffus
#2 PostAuthor: Taffus » Mon Aug 12, 2013 12:53 pm
or could the valve stem oil seals :wink:
KeithZ1R
#3 PostAuthor: KeithZ1R » Mon Aug 12, 2013 1:08 pm
+1
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
zman
#4 PostAuthor: zman » Mon Aug 12, 2013 2:03 pm
Have fitted new stem seals.Would still then smoke on overrun.wouldnt it :?:
#5 PostAuthor: ZedHead » Mon Aug 12, 2013 2:27 pm
put a teaspoon of oil in plug 1 and do the compression test again .. if there a big difference you have a ring/bore issue. Out of curiosity what head gasket did you use?
zman
#6 PostAuthor: zman » Mon Aug 12, 2013 2:31 pm
would oil in plug 1 show if its just the oil ring.I used a standard gasket.Didnt know it was a high compression engine till it was all back together
Re: ===
#7 PostAuthor: ZedHead » Mon Aug 12, 2013 2:38 pm
zman wrote:would oil in plug 1 show if its just the oil ring.I used a standard gasket.Didnt know it was a high compression engine till it was all back together
The oil just helps to improve the seal if there is a problem, head and barrels would have to come off for further investigation. Head gasket could be a problem. Have you re torqued it?
Taffus
#8 PostAuthor: Taffus » Mon Aug 12, 2013 2:59 pm
you could try a leak down test
#9 PostAuthor: z1bman » Mon Aug 12, 2013 3:25 pm
did you check the valve guides for wear when you replaced the oil seals. what oils seals did you use? you could remove the carbs + exhaust + have a look at the valve stems to see if any oil is leaking down the back of the valves. you could have an oil leak between the oil way + the cylinder if its on no 1 or no 4
zman
#10 PostAuthor: zman » Mon Aug 12, 2013 3:46 pm
will do oil in No1 & try & rig up leak down test tomorrow.
I had been thinking that oil way may be leaking into No1,Not sure how i will check that
Users browsing this forum: No registered users and 150 guests
