Sooty plugs
ac/dc
Sooty plugs
#1 PostAuthor: ac/dc » Wed Aug 21, 2013 6:41 pm
Hi All tech heads
I have the 2 left plugs running reasonably clean
The 2 right plugs well sooted up
Setting are about the same on all the carbs
Is this a sign of a failing coil ?
Bike is a UK 1976 Z900 A4
#2 PostAuthor: z1bman » Wed Aug 21, 2013 6:49 pm
not coil related as it would affect cylinders 1+4 or 2+3. probably carb related invest in a colour tune
#3 PostAuthor: Pigford » Wed Aug 21, 2013 7:29 pm
Still could be electrical? :shock: Have you got +12v at coils when bike is running?
Swap (1 & 2 - with 3 & 4) spark plugs - HT leads & caps.
Run bike whilst on centre stand (keep it level) - turn off fuel then stop engine. Drain each carb & measure what comes out each & compare qty.
ac/dc
help
#4 PostAuthor: ac/dc » Thu Aug 22, 2013 8:22 pm
Thanks both for the comments
Mark will try what you have said over the weekend and let you know
Malc
Users browsing this forum: No registered users and 142 guests
