oil ring
zman
oil ring
#1 PostAuthor: zman » Thu Aug 22, 2013 1:03 pm
Is it possible to have oil passing the oil ring even if you still have perfect compression :?: And not pressurising the crank :?:
keep thoses wheels turning
#2 PostAuthor: chrisu » Thu Aug 22, 2013 1:07 pm
yes
if its a 3 part ring and not assembled correctly
the oil scraper part ends needs to 'butt up' and not overlap
zman
#3 PostAuthor: zman » Thu Aug 22, 2013 1:21 pm
This is a leek that has developed.So if its the problem,is eather worn or broke
#4 PostAuthor: chrisu » Thu Aug 22, 2013 1:54 pm
the one i described will be obvious on first startup so probably not then.
#5 PostAuthor: zed1015 » Thu Aug 22, 2013 2:51 pm
Where is the leak from ?
Oil getting into the bore will show itself as excessive smoke from that cylinders exhaust.
Oil in the port is most likely valve stem seal / worn guide or loose guide.
zman
#6 PostAuthor: zman » Thu Aug 22, 2013 3:35 pm
Its leaking in No1. not sure where from.Having the guids checked.
compression good.gasket good
StevieT
Re: oil ring
#7 PostAuthor: StevieT » Thu Aug 22, 2013 4:52 pm
zman wrote:Is it possible to have oil passing the oil ring even if you still have perfect compression :?: And not pressurising the crank :?:
Oh yes. Offers no or little resistance to combustion gases its full of holes!
Don't ignore the 2nd ring though, as this ring also helps to control oil. It's likely to have a tapered profile on the OD with a sharp lower edge, assuming its installed correctly?! It's designed to ride over the oil on the cylinder wall on the up stroke for lubrication of the ring pack, pretty much the same way as a water skier rides over water, but scrapes oil down on the downward stroke with the sharp edge created by the taper.
Z1A
Users browsing this forum: Bing [Bot] and 40 guests
