Hi All tech heads
I have the 2 left plugs running reasonably clean
The 2 right plugs well sooted up
Setting are about the same on all the carbs
Is this a sign of a failing coil ?
Bike is a UK 1976 Z900 A4
Sooty plugs
Still could be electrical?
Have you got +12v at coils when bike is running?
Swap (1 & 2 - with 3 & 4) spark plugs - HT leads & caps.
Run bike whilst on centre stand (keep it level) - turn off fuel then stop engine. Drain each carb & measure what comes out each & compare qty.
