Harris magnum Z1100R
Battery for Harris
I've changed the seat on my Magnum 1 and now looking for a small battery to turn over the 1170 Z1100R1 Wiseco motor. Needs to be 18 amp. Any ideas on lay down gel type batteries or similar? I've found a few, but they want lots of money!
Rod
Rod
						Have you had a look at these,but still cost a few quid
http://carrotcycles.co.uk/index.php?_a= ... cat_id=217
PUM 451
						HowieD wrote:I have a Racing Batteries one - more power and much smaller than lead acid but as you say more expensive.
Have you thought about relocating it to under the tank or behind the engine ???
Have thought about it, but decided to stick with the seat box. When you say racing battery, is it the lay down type? I've got a Red Devil that I bought from Lester about 10 years ago, it works but it's much to big.
Rod
						stempy wrote:Have you had a look at these,but still cost a few quid
These are good, but I don't think you can lay them on their side.
						RACING BATTERIES
they can be put any way up.
Racing Batteries that is.
						Re: RACING BATTERIES
HowieD wrote:they can be put any way up.
I'll keep the original until I find "the one". Need something lighter and smaller, that way I have space for a small toolkit, which can be handy on a long run.
						Dry build is finally happening. We took 3 inches off the seat for more room and a better angle. My mate did a great job on the exhaust with a nice titanium can. Loads more to do, new A10 headlight on the way and a few other bits and pieces, before the paint and polish.
[url][URL=http://s1231.photobucket.com/user/magnum112/media/IMG_0683.jpg.html]
[/url][/url]
[url][URL=http://s1231.photobucket.com/user/magnum112/media/IMG_0681.jpg.html]
[/url]
[/url]
[/url][/url]
[/url]
[/url]
						HowieD wrote:two questions:
is that a standard Harris Swinging Arm and if so where did you get the Rear Hugger ??
Want want want !!!
regards
Howie
Polygon swingarm made from alloy tube. I had it made years ago to take the ZZR wheel. It will be polished or anodised. You can see it better here;
Note how much the new seat has been modified. Kept the old paint because my mate sprayed it. New paint will vary, but still looking at the green.
Hugger was adapted from a GSXR600 Suzuki fitment. You have to cut it about, but it's worth it to keep all the crap out the carbs and shock. When I took her to Norway it poured down, but no water got in there.
						- paul doran
