A bit of advice when rebuilding a Z1000 engine.
Paul Whitehouse
#1 PostAuthor: Paul Whitehouse » Thu Aug 29, 2013 2:15 pm
Hi, a quick question about a `ticking` noise when manually turning over a recently re-built Z1000-A1 engine.
The engine is standard and I'm at the stage where the engine is in the frame, gearbox, barrels, head, camshafts and chain are all in place. The clutch is not yet fitted. The engine is in neutral. When turning the engine over in a clockwise direction (points side) I get a `ticking` noise coming from the gearbox behind the clutch (the rivets in the clutch appear ok)...the clutch is turning in an anti-clockwise direction as I'm doing this. When I turn the engine over in an anti-clockwise direction the noise disappears.
Thought I'd ask the question now before I get too far down the re-build road...and I'm getting a bit paranoid about having to split the engine casings !!!!
Cheers.
If it's too loud....too bad.
#2 PostAuthor: zed1015 » Thu Aug 29, 2013 3:10 pm
Hard to comment without actually seeing / hearing it.
Is it a loud ticking accompanied by some resistance or just a general mechanical noise generated by the gears meshing or the oil pump etc.
Maybe a dodgy or contaminated bearing.
You could double check that any gear dogs are not touching or too close to adjacent ones while in neutral which would indicate a bent selector fork but chances are it's nothing.
Paul Whitehouse
#3 PostAuthor: Paul Whitehouse » Thu Aug 29, 2013 4:34 pm
Hi mate, thanks for the reply,,,when turning the engine over I would say it is a loud ticking / clicking....it occurs roughly every 30 deg....as if it is a gear meshing issue or something similar...the oil pump isn't fitted yet. I'll check what you've suggested so far.
z1aphil
#4 PostAuthor: z1aphil » Thu Aug 29, 2013 5:40 pm
Just an idea (it happened to me).
Have you got BOTH of the bearing retaining half rings in place ?? one on each shaft.
Good luck. :D
#5 PostAuthor: zed1015 » Thu Aug 29, 2013 6:06 pm
Paul Whitehouse wrote: When turning the engine over I would say it is a loud ticking / clicking....it occurs roughly every 30 deg....as if it is a gear meshing issue .
Check the kickstart mechanism, that's the only item that would produce a loud click, especially at specific rotational angles.
Have you got the return spring fitted yet ?
#6 PostAuthor: z1bman » Thu Aug 29, 2013 6:20 pm
agree with zed1015 kick start ratchet gear is not under tension if the spring has not been fitted. ? or isn't located in the crankcase correctly
Paul Whitehouse
#7 PostAuthor: Paul Whitehouse » Thu Aug 29, 2013 6:47 pm
You've hit the nail on the head chaps...brilliant...many thanks. I've retained the kick start mechanism, but have hidden it behind a custom made `blank`...(I can't use the kick start as I'm running a V&H Sidewinder pipe) in my eagerness to see what this lovely polished `blank` would look like fitted I had forgotten to fit the spring !!!!!...I've just removed the `blank`, turned the engine over and I can see the kick start mechanism moving in time with the `clicks`.....thanks again chaps.
pertonpc
#8 PostAuthor: pertonpc » Thu Aug 29, 2013 9:46 pm
Hi There
Glad you got sorted.
There is a nice series of magazine articles by Dave Marsden from Z Power on here which you might find useful.
http://www.zedrider.co.uk/magazine-articles.html
All about stripping, inspecting and rebuilding the Z900/ 1000 motor.
From Mark
Paul Whitehouse
#9 PostAuthor: Paul Whitehouse » Fri Aug 30, 2013 4:55 am
Thanks Mark...I've downloaded the files...looks as though they'll come in handy !!!....thanks again guys.
