Metmachex Swing Arm Help
Fred the Zed
#1 PostAuthor: Fred the Zed » Sun Sep 15, 2013 10:04 am
I have a Metmachex swing arm lounging around in my garage doing not a lot. I bought it for my Z1R but have changed plans and I'm fitting a Dresda unit instead.
While the original arm was off my Z1R yesterday, I offered the Metmachex arm up and found the pivot was about 5mm too narrow to fit the Z1R. I've measured it at 226mm (roughly). There's no marking on the Metmachex arm to indicate what it might fit.
When I bought it, I was told it was for a Z650 / Z900 / Z1000, so assumed (now there's a word at the centre of most *uck-ups) it would fit.
From the photos, its clearly for a twin shock bike, has mounts for the brake torque arm on both the upper and lower side of the RHS, which may indicate its for a bike that has either a drum or disc rear brake. Any ideas?
[img][img]http://i1273.photobucket.com/albums/y413/FredtheZed/SwingArm1_zps21e9208c.jpg[/img]
[/img]Image
[img][img]http://i1273.photobucket.com/albums/y413/FredtheZed/SwingArm2_zpsd55193ff.jpg[/img]
Any ideas??
Fred[/img]
Paid Up Member
Taffus
#2 PostAuthor: Taffus » Sun Sep 15, 2013 10:46 am
they usually stamp the model fitment on the swing arm pivot tube
Charlie
#3 PostAuthor: Charlie » Sun Sep 15, 2013 3:29 pm
On the Z650 Metmachex, both spindles measure 315mm long from the base of the head to the end of the threads.
The pivot spindle is 16mm and the axle spindle is 17mm, which is 3mm smaller than on the Z900/1000 axle spindle.
I have the spindles in my garage from my Z650 MM arm but not the swingarm itself so I cannot measure the dimensions of that. As said, the model fitment on Metmachex swingers is stamped on the front edge of the swingarm pivot.
Mine says Z650/750.
Is that one gonna be for sale ?
KeithZ1R
#4 PostAuthor: KeithZ1R » Sun Sep 15, 2013 3:44 pm
should it have end caps ?
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
oldtimer
#5 PostAuthor: oldtimer » Sun Sep 15, 2013 3:58 pm
Taffus wrote:they usually stamp the model fitment on the swing arm pivot tube
Mine was clearly stamped on a flat area of the pivot tube Z1000, it also had end caps which I had to modify to fit on my Z900.
Fred the Zed
#6 PostAuthor: Fred the Zed » Sun Sep 15, 2013 5:07 pm
Charlie wrote:On the Z650 Metmachex, both spindles measure 315mm long from the base of the head to the end of the threads.
Mine says Z650/750.
Hi
Yep its for sale, but it would be nice to be 100% sure what it was made for. On the plus side, a couple of spacers and it could clearly fit the Z1000 / Z1R. PM me if you are interested in purchasing it. It's going on Ebay on Thursday evening if it doesn't sell beforehand.
Fred
Paid Up Member
Fred the Zed
#7 PostAuthor: Fred the Zed » Sun Sep 15, 2013 5:08 pm
KeithZ1R wrote:should it have end caps ?
Yep, the pivot tube is machined so that the caps clip on.....
Fred
Paid Up Member
garyd
#8 PostAuthor: garyd » Sun Sep 15, 2013 5:26 pm
Possibly a H****...I think they were generally slightly narrower at the pivot point.
Is Vic There
#9 PostAuthor: Is Vic There » Mon Sep 16, 2013 5:04 am
PM sent
KeithZ1R
#10 PostAuthor: KeithZ1R » Mon Sep 16, 2013 10:33 am
Fred
So that will be where the 5mm went then :D
Keith
:bop :gom
mistaken.
Fred the Zed
Further measurements
#11 PostAuthor: Fred the Zed » Tue Sep 17, 2013 5:14 pm
The arms measurements are:
Pivot width - 226mm
Space between insides of the rear chain adjusters - 226mm
Space between shock mountings - 260mm
Distance between centre of Pivot and centre of chain adjusters - 505mm
Fred
Paid Up Member
Is Vic There
#12 PostAuthor: Is Vic There » Tue Sep 17, 2013 8:07 pm
Just being very lazy as I can't measure my bike for over a week or so!
With the great wealth of experience on here, can anyone tell me if this would fit a Z1000R 1983 year?
Thanks in advance.
Is Vic There
#13 PostAuthor: Is Vic There » Wed Sep 18, 2013 9:09 am
So does anyone know if this will fit on a Z1000R?
Fingers crossed it will!
Fred the Zed
#14 PostAuthor: Fred the Zed » Wed Sep 18, 2013 6:24 pm
Oh, and the rear wheel axle / spindle is 20mm diameter.
Fred
Paid Up Member
Is Vic There
#15 PostAuthor: Is Vic There » Wed Sep 18, 2013 8:14 pm
So can anyone have an informed guess if this would fit?
As you know to get it down here is going to cost a fortune, just want to make sure it will fit, if it needs minor modifications that's fine!
Your thoughts Gents?
Users browsing this forum: No registered users and 107 guests
