coil mod
royboy
coil mod
#1 PostAuthor: royboy » Sun Sep 22, 2013 5:08 pm
hi all having problems with mod wired up as per instructions but with kill switch in off i'am getting power and when in run there is no power,
I have electronic ignition boyer bronsden not dyna s.do I have to some thing
to that,only getting 9.46 at coils before.
#2 PostAuthor: z1bman » Sun Sep 22, 2013 5:33 pm
what colour wire from the kill switch have you connected to terminal 86 of the relay?
royboy
mod
#3 PostAuthor: royboy » Sun Sep 22, 2013 8:09 pm
hi z1bman
put the wire to the yellow wire from one of the coils.
#4 PostAuthor: z1bman » Sun Sep 22, 2013 8:18 pm
is the other coil still connected to the yellow/red wire ?
royboy
#5 PostAuthor: royboy » Sun Sep 22, 2013 8:36 pm
hi no main wire disconnected,and new wire to 87 is connected
#6 PostAuthor: z1bman » Sun Sep 22, 2013 8:44 pm
85 on the relay should be earth + 30 should positive fuse protected
royboy
#7 PostAuthor: royboy » Sun Sep 22, 2013 8:51 pm
hi that is what I have got
#8 PostAuthor: z1bman » Sun Sep 22, 2013 9:00 pm
disconnect the yellow/red from the relay + see if you lose the 12v feed from this wire when you turn the kill switch of
royboy
#9 PostAuthor: royboy » Sun Sep 22, 2013 9:11 pm
will look in the morning
royboy
#10 PostAuthor: royboy » Tue Sep 24, 2013 6:00 pm
I have sorted it out now,it was the 5 pin relay for some reason pin 87a was allways live,put 4 pin relay on now all is working as it should.
thanks for the help
KeithZ1R
#11 PostAuthor: KeithZ1R » Tue Sep 24, 2013 7:20 pm
royboy wrote:I have sorted it out now,it was the 5 pin relay for some reason pin 87a was allways live,put 4 pin relay on now all is working as it should.
thanks for the help
5 pin relays are normally "changeover" units they have a common, normally open and normally closed and two connections for the coil
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
Users browsing this forum: No registered users and 108 guests
