Z1R Switchgear
- Fred the Zed
Z1R Switchgear
I've fitted flatter bars to my Z1R and I'm wondering what to do about the switchgear. Obviously on a Z1R the electrical cabling runs through the original bars but I dont want to start drilling holes in the new ones as it will weaken them. Has anyone found a solution to this, either by fitting aftermarket switchgear or by fitting later Kawasaki switchgear?
Fred
Fred
Paid Up Member
- Fred the Zed
Yep!
Its a pain alright. I did fit lower steel bars, but would still rather not chop them up. If only to avoid having to thread the cabling through again.......
While I was at it I dry fitted a more modern front mastercylinder too (off a GSXR10000 K2) and a quick action throttle with new cables to complement the Keihin CR Specials as the old throttle was a bit worn and sticky. Lovely and crisp action now. Need to measure up new braided brake lines so I can junk the Wallace and Gromit designed remote master cylinder.
I'll get around to fitting the swingarm and the CMAs one day too...
Never enough hours in the day.
Fred
Fred
Paid Up Member
- Fred the Zed
I was thinking of forking out for a set of PMC replica switches, but its an expensive option.....
http://japan.webike.net/KAWASAKI/Z1-R/H ... 9/1030/mc/
Although they are a quite reasonable £35 ish each side, the postage is £40 from Japan and I can't actually be sure that the cabling runs outside the bars as it might be a generic picture... hmm decisions decisions
Fred
Fred
Paid Up Member
I drilled and filed/dressed the holes in a set of bars that i put on my Z1R .
Then insulation taped up the switchgear wires and made a kind of rounded end so as not to snag while threading .
Smothered the cable in grease and 30 seconds later the cable was out through the centre .
It really was a piece of .
I didn't need to thread a fish wire through first or owt like that .
It actually was a lot easier than i expected .
0172 . Geoff Parr
Saw some switches at D&K off a kz550ltd. These look very similar to the Z1r switches complete with the self canceling solenoid hanging off the bottom. The wires on the top part of the switch exit out the back through a nice rubber seal. Not saying that these will fit a standard z1r but will give you an idea of how to modify your switches.
- Fred the Zed
lescr wrote:Saw some switches at D&K off a kz550ltd. These look very similar to the Z1r switches complete with the self canceling solenoid hanging off the bottom. The wires on the top part of the switch exit out the back through a nice rubber seal. Not saying that these will fit a standard z1r but will give you an idea of how to modify your switches.
I'll have a look..... well spotted that man!
Fred
Paid Up Member
- Fred the Zed
Fred the Zed wrote:lescr wrote:Saw some switches at D&K off a kz550ltd. These look very similar to the Z1r switches complete with the self canceling solenoid hanging off the bottom. The wires on the top part of the switch exit out the back through a nice rubber seal. Not saying that these will fit a standard z1r but will give you an idea of how to modify your switches.
Fred
Found it....Yep, I see your point, its a shame that this particular one is in such shocking condition else I might have bought it to use. The search goes one.
Fred
Paid Up Member
- Fred the Zed
most of the wiring should be adaptable what doesn't fit you can use/ cut + solder from your old switch or buy the correct type terminals from vehichle wiring products
http://www.vehicle-wiring-products.eu/V ... blades.php
http://www.vehicle-wiring-products.eu/V ... ectors.php
Fred the Zed wrote:Hey Z1Bman
Your encyclopaedic knowledge of Z parts is outstanding. Obviously this uses plugs rather than bullet connectors, but any idea if its adaptable to use on a Z1R?
Fred
yes
Keith
mistaken.
Phil Churchett winner 2013
mistaken.
- Fred the Zed
- Fred the Zed
KeithZ1R wrote:Fred the Zed wrote:Hey Z1Bman
Fred
yes
Errr.... No! The wiring is completely different and I can't fathom how to adapt the new switchgear to fit the old loom. Doh.
Paid Up Member
Users browsing this forum: No registered users and 122 guests
