so the H has decided to throw a wobbly again !!
It runs then it doesn't then it runs then it doesn't !
Anyway after stripping everything down rewiring the injection loom changing everything pump, regulator, relay cleaning the injectors you name it I've done it, to no avail. so on day 4 I for got to attach the temp sensor wire and it ran !! attach it, it doesn't replaced the sensor with a good one same thing doesn't like it
it runs crisp probably better than ever with it not connected so is it the brain ? I would have thought it wouldn't run with it connected
also why would it be intermittent it ran last week for a whole day with it connected all of the loom has been replaced so no faulty joints etc
Anybody got any ideas ?
z 1000h again
z 1000h again
Gravity is a myth ...... The earth sucks
1000H
yeah I know Ollie, logic says it shouldn't run without a signal,
took it for a ride today wouldn't pull missing like a pig, further investigation needed would prefer a H over a MKII but the carbs are on the bench !!
Users browsing this forum: Bing [Bot] and 119 guests
,mmmmmm errrrrr ..lol ,they are strange beasts these H's ,mine wouldn't run without it connected.So ive no idea why yours is doing that
