530 front sprocket blues
Big Fluff
#1 PostAuthor: Big Fluff » Tue Oct 15, 2013 8:15 am
As I have converted my Z1000J special over from 630 to 530 drive, I still need a front sprocket (18 tooth) and a chain, which I intend to get from Stafford this Saturday.
Can anyone please confirm the following:
    Off what model bike will suit the 530 sprocket I need (i.e. 1992 Kawasaki EN500)
    How many links do I need in the 530 chain to suit 38 tooth rear sprocket and 18 tooth front sprocket
I have searched this site until I'm blue in the face, and can't find anything where it says "Kawasaki EN500 18t front sprocket" or whatever model may fit.
Sure there's loads saying Debben or Talon do them, but what model Kawasaki has the same on?
Thanks, Will
Big Fluff
#2 PostAuthor: Big Fluff » Tue Oct 15, 2013 12:04 pm
I've sussed it out myself...
Here is a list (from JT Sprockets) of all Kawasakis that have a 530 front sprocket that will fit straight onto the Z1000J, Z1000R, Z1100R, GPz1100B1/2 engine:-
16 Teeth
GPZ750 R (ZX750 G2-G3) 85-88
ZR1100 A1-A4 Zephyr 92-95
ZR1100 A1-A4,B1 Zephyr 91-97
17 Teeth
GPZ900 R A1-A6 (ZX) Ninja 84-89
GPZ900 R A7-A12 (ZX) Ninja 90-96
ZX900 A1-A3 Ninja 84-86
ZX900 A1L Ninja 84
ZX1100 D1-D9 Ninja (ZX-11) 93-01
ZZ-R1100 (ZX1100 D1-D5) 93-97
ZZ-R1100 (ZX1100 D3-D6) 95-98
ZZ-R1100 (ZX1100 D6-D7) 98-99
ZZ-R1100 (ZX1100 D8-D9) 00-01
ZX1200 C1-C4 Ninja (ZZ-R) 02-05
ZZ-R1200 (ZX1200 C1-C4) Ninja 02-05
ZX-14 (ZX1400 A6F,A7F,A8F) Ninja 06-08
ZX-14 (ZX1400 C9F,CAF,CBF) Ninja 09-11
ZX-14 (ZX1400 ECF,EDF,EDFA) Ninja 12-13
ZX-14 (ZX1400 FDF,FDFA) Ninja ABS 13
ZX-14 (ZZR-1400) 06-10
ZX-14 A6F/A7F/C8F/C9F/CAF/CBF Ninja (ZX1400) 06-11
ZX-14 ECF/ECFA/EDF/EDFA Ninja (ZX1400) 12-13
ZX-14 FDF/FDFA Ninja (ZX1400) ABS 13
ZZR1400 B6F,B7F,D8F,D9F,DAF,DBF 06-10
ZZR1400 ECF,FDF 11-12
ZZR1400 Performance 11-12
ZZR1400 Special Edition 13
18 Teeth
ZX-12R (ZX1200 A1,A2) Ninja 00-01
ZX-12R (ZX1200 B1,B2,B3,B4) Ninja 02-05
ZX1200 A1-A2 Ninja (ZX-12R) 00-01
ZX1200 B1-B4 Ninja (ZX-12R) 02-05
18 tooth front sprocket and 38 tooth rear sprocket is about right for most applications.
These are the dimensions for the standard 630 sprocket:
and these are the dimensions for the 530 sprocket (JTF517).
It should be noted that there is no offset on the 530 sprocket. However, with the thinner chain I'm hoping the chain will clear the engine.
tlc
#3 PostAuthor: tlc » Tue Oct 15, 2013 12:06 pm
Some very useful info there Will.
Out of interest what size tyre will you be using and will it require an offset sprocket?
Big Fluff
#4 PostAuthor: Big Fluff » Tue Oct 15, 2013 12:24 pm
tlc wrote:Some very useful info there Will.
Chris
I'm using a 120/17 on the front and a 150/18 on the rear.
I've got the rear sprocket running as close as absolutely possible to the swingarm, so I'm hoping when I pop the wheel in tomorrow night, it will clear the swingarm. :roll: :roll:
As for clearing the engine without an offset, I'll have to wait until I get a 530 sprocket. It may be that a flat sprocket will be no good, and if that's the case then I will have to approach Debbens or similar for an offset 530 sprocket to fit the 'J' derived engine, which is different to the Z1 derived engines.
I'll update my thread in the projects area with my findings... good or bad!
http://www.z1ownersclub.co.uk/forum/vie ... hp?t=18357
#5 PostAuthor: ADRIAN H » Tue Oct 15, 2013 1:49 pm
There is a link for 630 to 530 conversions on Z1 Enterprises web site.
http://www.z1enterprises.com/Chain630To530.aspx
Padders
#6 PostAuthor: Padders » Tue Oct 15, 2013 4:21 pm
I have just fitted a 3/8 offset 17t 530 front sprocket to go with a 46t rear as recommended by Al and Ray Debben for a J running 17inch wheels. The standard sprocket ran the chain too close to the tyre the 5/8 too close to the frame.
PUM 13
sockpuppet
#7 PostAuthor: sockpuppet » Tue Oct 15, 2013 5:52 pm
If you do need some offset this may help,
One or my 1100b2`s has zx10 wheels (tyre width 160) and I used a zx10 front sprocket .
for dimensions look on jt sprockets website for JTF527
My other b2 has a 180 tyre and uses an eary model zzr1100 sprocket
that has a bit more offset, -- JTF528
Both these are only up to 17 teeth though so you would have to go up to about 45teeth on the rear.
Mick
PS I`d have put the pics on but i couldn`t work out how to do it . :roll:
Big Fluff
#8 PostAuthor: Big Fluff » Tue Oct 15, 2013 8:39 pm
Mick. Thank you, that is exactly the info I need. Good man.
Padders
#9 PostAuthor: Padders » Tue Oct 15, 2013 9:10 pm
Chain wise my 17 front and 46 rear uses a 118 link chain
PUM 13
#10 PostAuthor: Ginger Bear » Wed Oct 16, 2013 5:12 am
Will,
Are you running an 18" rear on this?
# 104
Big Fluff
#11 PostAuthor: Big Fluff » Wed Oct 16, 2013 7:04 am
Ginger Bear wrote:Will,
Yes Steve... why can you shed any more light :roll:
#12 PostAuthor: Ginger Bear » Wed Oct 16, 2013 12:41 pm
Will, as in my pm I ended up with a 45t rear & I think an 18t front on 17" wheels & to be honest is was still a little over geared, Padders's 17/46 sounds good, even for 18" wheels.
If you start 'big' & work down, at least you can keep shortening the chain. :wink:
# 104
big green bus
#13 PostAuthor: big green bus » Wed Oct 16, 2013 3:54 pm
If you go on the JT site put your bike in it will show the standard sprocket and the ratio's at the bottom is you can check if you change the sprockets you don't get them too far out. let me know what the back wheel is and I will look for the correct sprocket for you as I have a JT sprocket book
Users browsing this forum: Maunders and 82 guests
