speedo drive
speedo drive
hi guys, has anybody out there in zedland got a speedo drive for a rickman driven off the rear axle, cheers phil.
- paul doran
z1bman wrote:does it resemble any of these?
http://www.ebay.co.uk/itm/370597021232? ... 1423.l2649
http://www.ebay.co.uk/itm/301004056060? ... 1423.l2649
Either of the two above should do the job.
Do note however that there is an additional spacer that is required the sits between the drive unit and drive plate.
Same drive unit for both cast and spoked wheel.
Absolute pleasure my friend. Anything Rickman related you require just give me a shout.75hmp wrote:now all sorted, a big THANK YOU to big fluff and z1bman for your help, life would be a lot harder if it was not for this great site and the great people who use it,thanks once again.
Regards Will
