Z1000R fork internals - parts needed!!!
martinz1000r
#1 PostAuthor: martinz1000r » Sat Nov 16, 2013 4:10 pm
Just changing my leaking fork seals. Whilst apart I spotted a couple of parts are missing. Anyone got any old forks or bits of internals lying around?
The bits i need are the large washers that sit on top of the springs 44028 in the diagram and the conical piece at the bottom of the damper rod. See picture below:
Can anyone help?
Garn 1
#2 PostAuthor: Garn 1 » Sun Nov 17, 2013 3:31 am
MatinZ, If it's a Z1R (Not sure about an ELR) then you often find the top washer missing, Don't worry too much about it, just put a normal washer in.
The conical piece must be there otherwise you could not assemble them., It may be jammed in the bottom and you just can't see it. Pretty hard to get if you have lost it! The Z1 thru to the Z1R are much the same!
Get you components side by side from each leg and take a photo.
martinz1000r
#3 PostAuthor: martinz1000r » Sun Nov 17, 2013 10:38 am
Is it the bit of the damper that the bolt goes in to? Is it just that exploded diagram that is confusing me?
#4 PostAuthor: z1bman » Sun Nov 17, 2013 10:48 am
fork spring washers 44028-1004 available from from cradley
#5 PostAuthor: z1bman » Sun Nov 17, 2013 11:07 am
martinz1000r
#6 PostAuthor: martinz1000r » Sun Nov 17, 2013 2:34 pm
z1bman wrote:http://www.ebay.co.uk/itm/221317817525?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.co.uk/itm/400499572663? ... 1423.l2649
Based on part numbers on Kawasaki.com the Z1000R fork internals are unique to that model. These would not be right but thanks for suggesting.
#7 PostAuthor: z1bman » Sun Nov 17, 2013 4:21 pm
the internals are different but the aluminium cup on the end of the damper rod are very similar in looks + dimensions
#8 PostAuthor: chrisu » Sun Nov 17, 2013 5:25 pm
if you really don't have the conical ally bits i've got some Z1R ones you can try to see if they suit - give me a PM.
Users browsing this forum: Maunders and 81 guests
