Z1000 LTD B3 SPECS
Z1000 LTD B3 SPECS
#1 PostAuthor: PAULJAC47 » Tue Nov 19, 2013 7:12 pm
Guyz Can anyone let me have following info.
Z1000 LTD B3 SPECS....Mk2 engine BHP,Rear and front sprocket standard number of teeth how does this affect gearing?if so what is the best combo to go for?,How was the speed limited to 80 m.ph,if at all on this model?
The old speedo only goes up to 80?but have now fitted 160mph type.The rear wheel has been changed to a standard z1000 one...Thanks PaulJ
Gus
#2 PostAuthor: Gus » Tue Nov 19, 2013 7:54 pm
Hi Paul
I make the motor to be 85bhp
Front sprocket 15
KZ1000-A1 (KZ1000) (1977)
KZ1000-A2 (KZ1000) (1978)
KZ1000-A2A (KZ1000) (1978)
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B1 (KZ1000 LTD) (1977)
KZ1000-B2 (KZ1000 LTD) (1978)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D1 (Z1R) (1978)
KZ1000-D3 (Z1R) (1980)
Rear sprocket 33
KZ1000-G1 (Classic) (1980)
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ700-A1 (1984)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-L3 (1983)
KZ750-R1 (GPz) (1982)
I thought that although the LTD had the 16" rear wheel the profile of the tyre made it the same overall diameter as an 18" standard wheel (I could be wrong :roll: again :roll: :roll: ).
According to Kawasaki.com the speedo from a B3 was also fitted to these models
Model (10):
KZ900-A4 (1976)
KZ900-A5 (1977)
KZ900-B1 (LTD) (1976)
Hope this helps
Gus
"Set the GRINDER on it"
doebag
#3 PostAuthor: doebag » Tue Nov 19, 2013 8:26 pm
I don't think they were restricted. The 80 max [55 mark] were just legislation things.
'Dying a'int much of a living, boy'
Outlaw Josey Wales
Member No. 555
tlc
#4 PostAuthor: tlc » Tue Nov 19, 2013 8:28 pm
Now you've fitted the 160 speedo it will be twice as fast.
#5 PostAuthor: PAULJAC47 » Tue Nov 19, 2013 8:52 pm
Thanks guys,sage words as ever Chris,how are you? Paul J
Redbeard
#6 PostAuthor: Redbeard » Tue Nov 19, 2013 10:17 pm
Hi Paul, is your speedo electronic or cable driven? Mine has the 80mph speedo too. Do you know which model 160mph speedo you replaced yours with?
#7 PostAuthor: PAULJAC47 » Wed Nov 20, 2013 6:24 pm
Its a cable unit i have fitted a KZ1000 unit,pretty sure this engine is the same as an st or mk11 think they kicked out 96bhp..Cheers
Redbeard
#8 PostAuthor: Redbeard » Wed Nov 20, 2013 10:01 pm
thanks paul. mine's the j engine with electronic speedo. :|
Big John
#9 PostAuthor: Big John » Wed Nov 27, 2013 9:37 pm
The speedo would have had 80mph marker but you would have been able to pass this with theneedle. Also LTD's were rated at a couple of bhp higher due to the freer flowing exhausts.
86 Z1100R x 2, z7/11r, ZRX400, Z1000B2, ,ZRX1100C4 & Z1000J3.
Users browsing this forum: Robw and 70 guests
