Guyz Can anyone let me have following info.
Z1000 LTD B3 SPECS....Mk2 engine BHP,Rear and front sprocket standard number of teeth how does this affect gearing?if so what is the best combo to go for?,How was the speed limited to 80 m.ph,if at all on this model?
The old speedo only goes up to 80?but have now fitted 160mph type.The rear wheel has been changed to a standard z1000 one...Thanks PaulJ
Z1000 LTD B3 SPECS
Z1000 LTD B3 SPECS
Hi Paul
I make the motor to be 85bhp
Front sprocket 15
KZ1000-A1 (KZ1000) (1977)
KZ1000-A2 (KZ1000) (1978)
KZ1000-A2A (KZ1000) (1978)
KZ1000-A3 (KZ1000) (1979)
KZ1000-A3A (KZ1000) (1979)
KZ1000-A4 (KZ1000) (1980)
KZ1000-B1 (KZ1000 LTD) (1977)
KZ1000-B2 (KZ1000 LTD) (1978)
KZ1000-B3 (KZ1000 LTD) (1979)
KZ1000-B4 (LTD) (1980)
KZ1000-C2 (Police 1000) (1979)
KZ1000-C3 (Police 1000) (1980)
KZ1000-C4 (Police 1000) (1981)
KZ1000-D1 (Z1R) (1978)
KZ1000-D3 (Z1R) (1980)
Rear sprocket 33
KZ1000-G1 (Classic) (1980)
KZ650-H1 (CSR) (1981)
KZ650-H2 (CSR) (1982)
KZ650-H3 (CSR) (1983)
KZ700-A1 (1984)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-L3 (1983)
KZ750-R1 (GPz) (1982)
I thought that although the LTD had the 16" rear wheel the profile of the tyre made it the same overall diameter as an 18" standard wheel (I could be wrong
again
According to Kawasaki.com the speedo from a B3 was also fitted to these models
Model (10):
KZ900-A4 (1976)
KZ900-A5 (1977)
KZ900-B1 (LTD) (1976)
Hope this helps
Gus
Front sprocket 15
Rear sprocket 33
KZ700-A1 (1984)
KZ750-E1 (1980)
KZ750-E2 (1981)
KZ750-E3 (1982)
KZ750-L3 (1983)
Model (10):
KZ900-A4 (1976)
KZ900-A5 (1977)
Hope this helps
Gus
"Set the GRINDER on it"
Its a cable unit i have fitted a KZ1000 unit,pretty sure this engine is the same as an st or mk11 think they kicked out 96bhp..Cheers
