PLASTIC WELDING - Anyone know more?...
I've got an original 73 side panel with good original paint which has a smallish but 'clean' fracture in the plastic.
Anyone know anyone who can 'weld' up this type of plastic successfully?
Also, can it be repaired 'invisibly' on the inner face so as not to damage the painted surface? Be a shame to lose the original paint.
Cheers - Chris
Cheers - Chris
- big green bus
use a soldering iron on the inside and push the plastic into the crack from sides like knitting try and find an old panel or something to cut a strip off to use as a filler rod. it must be off a bike to make sure you get the same type of plastic. i think it is ABS, but am not sure if you are carefull you will end up with a hair line crack on the front but no paint damage. the trick is to take your time.
try tigwell williams coach works, just down the road from you in slough
01753 682176
Or if your brave try
http://cgi.ebay.co.uk/SEALEY-Plastic-We ... dZViewItem
01753 682176
1972 Z1 Euro Spec
1975 Z1B UK Bike
1972 Z1 Euro Spec
1975 Z1B UK Bike
- steve bowdler
jam
If you can find it there's a product in some car auto shops called VersaChem plastic welding system, it's a two part epoxy based system and it's brilliant, I've rebuilt whole lugs and missing sections with it. Unfortunately it is no longer imported into this country from the states, so it may be hard to find, in fact if you do find any buy it all, it's about 4 quid a pack, as I'll have some off you. Failing that the Wurth system is virtually identical but a hell of a lot more expensive.
- steve bowdler
If this is afore mentioned stuff http://www.amazon.com/Versachem-Plastic ... B0002JN5G0 $3.99 plus postage.
jam
That's the stuff, it's absolutely fantastic kit. I've used it on loads of repairs and had no failures yet with it. I can't get it in the UK any more, as the importers can't bring it in due to kitemark packaging problems. If anyone can find a way of getting it into the UK I'd take as much as I can get hold of. It's easy to use and very similar to the Wurth system, but loads cheaper. it's very very strong and can be used for joining different types of plastic, which makes it ideal for one off body parts for streetfighters and suchlike. If anyone can get it let me know please.
Steve Cooke
- ZedHead
jam
I just got this e-mail today regarding Versachem Plastic Weld
Dear Sir
I have been given your details by ITW in the US regarding your interest in Plastic Weld.
We have this product available in 28ml, 50ml and 400ml cartridges.
If we can be of any assistance please do not hesitate to let me know.
Kind regards
Warren Wilkinson
warren@bondloc.co.uk
01299-269914 direct line
Dear Sir
Kind regards
Warren Wilkinson
