does it fit
stevo1100
does it fit
#1 PostAuthor: stevo1100 » Mon Dec 23, 2013 11:23 am
I have a spare gpz 1100 none injection head.does it fit a z1000 engine. :?:
#2 PostAuthor: zed1015 » Mon Dec 23, 2013 11:36 am
It bolts straight on but you need an APE top idler tower or similar for the camchain and you will also lose 2 points of compression so will need to compensate for that.
stevo1100
head
#3 PostAuthor: stevo1100 » Mon Dec 23, 2013 12:00 pm
thanks for the reply.a friend bought a z1000 minus the head so I will pass it on
#4 PostAuthor: zed1015 » Mon Dec 23, 2013 1:19 pm
If it's the unitrack head the valve angles are steeper too so need to watch the piston/valve clearances too.
Users browsing this forum: No registered users and 76 guests
