1000J Fuel tap repair kit
Big Fluff
#1 PostAuthor: Big Fluff » Mon Dec 30, 2013 2:39 pm
Just so I don't have any trouble with the newly built Lawson replica, I want to fit a new fuel tap kit.
All the kits I've seen on Wemoto, eBay, Z-Power etc. don't match what I need :??
Here is a pic of my fuel tap off my 1983 Z1000J2.
You can see that the "gasket" (as Kawasaki call it, round disc below the diaphragm) has 1 hole in the middle and 4 around the outside.
Here is a pic of the one Z-Power and every other shop sell. Quite clearly this is different, with no hole in the middle and 5 around the outside!
Has anyone come across this problem before and where the hell do I get the correct kit from :?:
Thanks, Will
sockpuppet
#2 PostAuthor: sockpuppet » Mon Dec 30, 2013 3:56 pm
Hi Will
Had a look in my Kawasaki manual and found illustrated breakdowns of two different fuel taps, ( its picture 6-11 if you have a manual )
Variation 1
listed as kz/z1000-j shows the one with the five holes around the outside ,
Variation 2
looks to be like you want with the hole in the centre -- this is listed as kz/z1000-K and M models
( i THINK these are the `Ltd custom` types - i`m sure someone will correct me if i`m wrong !!)
Have you tried NRP in Manchester ? , i`ve always found them very helpful.
http://www.nrp-carbs.co.uk/index.htm
Hope this helps
Regards Mick
P.s Your Bike is looking great ! :drool
sanderz
#3 PostAuthor: sanderz » Mon Dec 30, 2013 4:00 pm
Have you tried NRP (carb specialists) Manchester?
http://www.nrp-carbs.co.uk/Kawasaki_fue ... ir_kit.htm
or an alternatively you could fit a Pingel tap (few quid tho') and have piece of mind.
http://www.debben.co.uk/Pingel.html
http://www.ebay.co.uk/itm/Kawasaki-Z100 ... 460d109232
Wots up DOHC
sanderz
#4 PostAuthor: sanderz » Mon Dec 30, 2013 4:02 pm
Jeeze Sockpuppet beat me to it - that's me an slow typing :oops:
Wots up DOHC
Big Fluff
#5 PostAuthor: Big Fluff » Mon Dec 30, 2013 4:43 pm
sockpuppet wrote:Hi Will
Variation 1
Variation 2
Hope this helps
Regards Mick
Cheers SP, I only have the 1000J IPC so I can't tell if it's the one I need or not.
If you are 100% sure that i need the K or M model kit, then I'll place an order.
Sorry to ask, I'm not judging your excellent knowledge, but just want to be sure before placing an order.
Many thanks, Will
Charlie
#6 PostAuthor: Charlie » Mon Dec 30, 2013 4:47 pm
If you need the 4 hole type, just order a GS750E fuel tap gasket from any Suzuki dealer. they are the same as the Kawasaki and still available as an OE part.
Part number is 44341-33150 They are are well under a fiver :wink: (about 3 quid rings a bell) I have one in my Kawasaki vac tap.
If you cant get one - I likely have a spare somewhere.
Redbeard
#7 PostAuthor: Redbeard » Mon Dec 30, 2013 4:58 pm
Will if you can hold on for a day or so I intend to overhaul mine (k/ltd model) so we can compare. I hope to strip it tomorrow and can take photos if that's any help.
Big Fluff
#8 PostAuthor: Big Fluff » Mon Dec 30, 2013 5:05 pm
Firstly Charlie - Thank you very much for your kind offer but I wouldn't want to take your spare. After all, I would rather have a complete tap kit
Thanks for the heads up on the Suzuki GS tap though, it's good to know. :wink:
Redbeard - Yes no probs mate, it's kinda strange why my UK spec Z1000J2 would have a Ltd tap fitted though.
The tap itself as can be seen by the pics above, is just your normal vac tap - vacuum stub on the rear facing forwards and the single main fuel supply stub facing inwards.
You can email me direct at barbers@rowanhouse1.demon.co.uk
Thanks, Will
jimmock
#9 PostAuthor: jimmock » Mon Dec 30, 2013 5:22 pm
Fluff,
newly built Lawson replica.....
Is it a genuine replica or a replica??
Jimmock. :wnkr
I hate people I don't like !
Big Fluff
#10 PostAuthor: Big Fluff » Mon Dec 30, 2013 5:23 pm
jimmock wrote:Fluff,
ELR Replica :lol:
jimmock
#11 PostAuthor: jimmock » Mon Dec 30, 2013 5:28 pm
ELR Replica :lol:
I'm even MORE confused now?? :geek
Jimmock. :wnkr
Big Fluff
#12 PostAuthor: Big Fluff » Mon Dec 30, 2013 5:34 pm
jimmock
#13 PostAuthor: jimmock » Mon Dec 30, 2013 5:42 pm
Crystal clear now.
A replica replica.
Jimmock. :wnkr
#14 PostAuthor: z1bman » Mon Dec 30, 2013 6:54 pm
part no 11009-1194 in stock at cradley
#15 PostAuthor: z1bman » Mon Dec 30, 2013 7:50 pm
Users browsing this forum: Google [Bot] and 45 guests
