Carbs
Wayne1960
Carbs
#1 PostAuthor: Wayne1960 » Wed Jan 01, 2014 9:32 am
Can anyone help with good topic and pics for reassembling my Mikuni carbs. They are the 26mm type for KZ900 A4.
Also can anyone tell me if I can replace the the brass needle that sticks out of the base of the main body. It has snapped in half!
Bike now finished what a joy!
Z1parR
#2 PostAuthor: Z1parR » Wed Jan 01, 2014 10:12 am
Wayne , the brass choke tube will twist out easily from the main body if you grip it with pliers .
PM me your address and i'll send you a whole one tomorrow .
I may have some pics of a complete set of 26s , i've certainly got pics of 28s .
They aren't that different visually , mainly the tickover adjustment really :D
0172 . Geoff Parr
Z1parR
#3 PostAuthor: Z1parR » Wed Jan 01, 2014 11:29 am
Apologies Wayne about the choke tube .
I've just taken this last one out of a carb and it's split right at the bottom by the jet .
I don't think anything can be done with it , unless somebody knows any different .
Can still supply carb pics .
0172 . Geoff Parr
Wayne1960
#4 PostAuthor: Wayne1960 » Wed Jan 01, 2014 12:53 pm
Thanks for trying at least I know it can be changed, I have just pulled out the old one, well what was left of it! Yes it came out easy so thanks.
I have also noticed the brass tube bit on the bottom cover has snapped off on one. I managed to pull out the bit on the other side which will know need replacing and I guess the bit lft in the body where the tube part has broken off will need drilling out.
Where can I get replacement parts?
Sent PM
Redbeard
#5 PostAuthor: Redbeard » Wed Jan 01, 2014 3:08 pm
I've bought jets from here before;
http://www.motocarb.co.uk/default.htm
I'm sure there will be varied opinions and more suggestions of part sources.
Compo1955
#6 PostAuthor: Compo1955 » Wed Jan 01, 2014 3:56 pm
Z1parR wrote:Apologies Wayne about the choke tube .
Could the split be filled in with solder ?
If it ain`t broke.....don`t fix it
C90
W650
ZRX1200R
Z1A
#7 PostAuthor: z1bman » Wed Jan 01, 2014 5:22 pm
try John browse?
Wayne1960
#8 PostAuthor: Wayne1960 » Sun Jan 05, 2014 12:30 pm
Thanks all
Quick question. When putting the carbs back together should I be lubricating the parts especially the the chokes??
000zeds
#9 PostAuthor: 000zeds » Sun Jan 05, 2014 2:57 pm
Any luck getting the tube :?:
Zeds-R-Us
Wayne1960
#10 PostAuthor: Wayne1960 » Sun Jan 05, 2014 6:54 pm
No unfortunately twozeds! Any ideas?
Users browsing this forum: No registered users and 126 guests
