Engine Details - KZT00JE040280???
#1 PostAuthor: Pigford » Tue Jan 07, 2014 1:22 pm
As title, I have a J engine that I may wanna sell - can anyone confirm what model it is please?
Engine Details - 998cc # KZT00JE040280
Its in fair condition - excellent compression - couple of damaged fins top l/hand side of head....
Ta :wink:
Redbeard
#2 PostAuthor: Redbeard » Tue Jan 07, 2014 6:31 pm
tlc
#3 PostAuthor: tlc » Tue Jan 07, 2014 6:51 pm
Or LTD
#4 PostAuthor: Pigford » Wed Jan 08, 2014 7:34 am
From the ZPOWER history section:
The fist model Z1000R1 was intended for America only and differed from the European models by having a genuine KERKER 4-1 black exhaust system. It came in one colour of course: Kawasaki Lime Green.
Z1000R2 1983
FRAME NUMBER: KZT00R-001101 ONWARDS
ENGINE NUMBER: KZT00JE-039301 ONWARDS
Its a LAWSON :twisted:
or a J3
Big Fluff
#5 PostAuthor: Big Fluff » Wed Jan 08, 2014 10:43 am
..which is identical to a 'J' Piggy :lol:
malmojoe
#6 PostAuthor: malmojoe » Wed Jan 08, 2014 2:23 pm
I think the inlet cams should different for the ELR. They are the same as B1/B2.
after a second look, it's hard to say, there are 2 part numbers for the inlet cams:
12044-1031 - appears on J1-3, ELR and B1/2 parts list, but that may just be so that the microfiche can be used for both.
12044-1037 - appears on R1/2 and B1/2, so I reckon that's the ELR one.
I'm sure I saw something on here about this before.
malmojoe
#7 PostAuthor: malmojoe » Wed Jan 08, 2014 2:45 pm
here's some details of cams J,R,B, so you can measure. :roll:
I got them from this thread.
http://www.kzrider.com/forum/2-engine/590239-stock-j-model-cam-options
1982 KZ1100-A2, rated as 92 hp:
Intake (12044-1027):
Duration: 270 - Lift: Not exactly sure, but a little less than the 81 GPz.
Exhaust:
Used on:
KZ1000-K1 (LTD) (1981)
KZ1000-K2 (LTD) (1982)
KZ1000-M1 (CSR) (1981)
KZ1000-M2 (CSR) (1982)
KZ1000-P1 to P24 (Police 1000) (1982 - 2005)
KZ1100-A1 (Shaft) (1981)
KZ1100-A2 (Shaft) (1982)
KZ1100-A3 (Shaft) (1983)
KZ1100-D1 (Spectre) (1982)
KZ1100-D2 (Spectre) (1983)
KZ1100-L1 (LTD Shaft) (1983)
ZN1100-B1 (LTD Shaft) (1984)
ZN1100-B2 (LTD Shaft) (1985)
1981 KZ1100-B1 Gpz, rated as 102 hp:
Intake (12044-1031):
Duration: 280 - Lift: 8,4 mm (.330") - Open: 35 BTDC - Close: 65 ABDC
Exhaust (12044-1036):
Duration: 280 - Lift 8,8 mm (.346") - Open: 68 BBDC - Close: 32 ATDC
Used on:
KZ1000-J1 (1981)
KZ1000-J2 (1982)
KZ1000-J3 (1983)
KZ1000-R1 (Eddie Lawson Replica) (1982)
KZ1100-B1 (GPz) (1981)
1982 KZ1100-B2 GPz, rated as 109 hp:
Intake (12044-1037):
Duration: 288 - Lift: 8,8 mm (.346") - Open: 34 BTDC - Close 74 ABDC
Exhaust (12044-1037):
Duration: 288 - Lift: 8,8 mm (.346") - Open 72 BBDC - Close 36 ATDC
Used on:
KZ1000-R2 (Eddie Lawson Replica) (1983)
KZ1100-B2 (GPz) (1982)
1983/84 ZX1100-A1/A2 GPz, rated as 120 hp:
Intake (12044-1057):
Duration: 300 - Lift: 9,6 mm (.375")
Exhaust (12044-1057):
Used on:
ZX1100-A1 (GPz) (1983)
ZX1100-A2 (GPz) (1984)
#8 PostAuthor: Ginger Bear » Fri Jan 10, 2014 2:27 pm
Piggy, I picked this up yesterday;
Engine No. KZT00JE 0406** With Oil cooler takes off's, so is this a Lawson :?
Didn't cost a lot either. :ek
# 104
Z1parR
#9 PostAuthor: Z1parR » Fri Jan 10, 2014 9:02 pm
It's a spectre engine that Steve :shock:
I'm glad you didn't pay a lot for it :tick :rake
0172 . Geoff Parr
Is Vic There
#10 PostAuthor: Is Vic There » Fri Jan 10, 2014 9:49 pm
So what's this out of - KZT10BE018792
I've been told a GPz1100 but which one ?
Z1parR
#11 PostAuthor: Z1parR » Sat Jan 11, 2014 12:57 am
GPZ1100 B2 . - Ian .
0172 . Geoff Parr
jimmock
#12 PostAuthor: jimmock » Sat Jan 11, 2014 1:37 am
If it is a Lawson,
Is it a genuine one or a replica?
Jimmock. :wnkr
I hate people I don't like !
jimmock
#13 PostAuthor: jimmock » Sat Jan 11, 2014 1:38 am
I notice there is now TWO Jimmocks.
The ORIGINAL and now one REPLICA!!!
Jimmock. :wnkr
Is Vic There
#14 PostAuthor: Is Vic There » Sat Jan 11, 2014 6:34 am
jimmock wrote:I notice there is now TWO Jimmocks.
There surly can only be one :shock:
#15 PostAuthor: Pigford » Sat Jan 11, 2014 8:57 am
Sorry Bear - yours is a later model than mine - not worth 'diddly-squat' :(
