Stainless bolts
Gavin
Stainless bolts
#1 PostAuthor: Gavin » Mon Jan 13, 2014 7:09 pm
Does anyone sell Z900 front and rear wheel axle and swinging arm bolts in Stainless steel.
Z1000 MK2
Z1300 DFI
#2 PostAuthor: ADRIAN H » Mon Jan 13, 2014 7:32 pm
Phil Denton Engineering do, but they are not quick.
#3 PostAuthor: z1bman » Mon Jan 13, 2014 7:42 pm
found these but they may as well be gold plated for that price :( :( :(
http://www.zpower.com.au/catalog/produc ... cts_id=327
#4 PostAuthor: chrisu » Mon Jan 13, 2014 7:58 pm
ADRIAN H wrote:Phil Denton Engineering do, but they are not quick.
They've been ok when I've used them.
Not 'next day' but not weeks either
#5 PostAuthor: ADRIAN H » Mon Jan 13, 2014 8:19 pm
Last time I used them, it took around 3 months for a rear brake push rod. Good quality job, though. I would give them a bell and check turn around. As I may have just been unlucky.
http://www.phildentonengineering.com/index.html
#6 PostAuthor: z1bman » Mon Jan 13, 2014 8:33 pm
Gavin
#7 PostAuthor: Gavin » Mon Jan 13, 2014 8:39 pm
What grade would be best to use as we have machining companies around here that may be able to make some up
Z1000 MK2
Z1300 DFI
z1000puddin
#8 PostAuthor: z1000puddin » Mon Jan 13, 2014 8:46 pm
I had front & rear stainless steel axles machined up for my green zed.
I used 17-4 grade stainless , but 303 grade would be more than strong enough.
Stu
Zed til Dead
#9 PostAuthor: chrisu » Mon Jan 13, 2014 9:46 pm
Ouch
jimmock
#10 PostAuthor: jimmock » Mon Jan 13, 2014 11:11 pm
A lot of engineering shops are very wary, or will not make spindles (axles) or swing arm pivots in stainless.
Jimmock. :wnkr
I hate people I don't like !
Gavin
#11 PostAuthor: Gavin » Tue Jan 14, 2014 5:16 pm
jimmock wrote:A lot of engineering shops are very wary, or will not make spindles (axles) or swing arm pivots in stainless.
Spoken to a couple around here , they said they can machine anything
Until I mentioned motorcycle wheel axles.
Z1000 MK2
Z1300 DFI
#12 PostAuthor: ADRIAN H » Tue Jan 14, 2014 5:36 pm
Gavin wrote:What grade would be best to use as we have machining companies around here that may be able to make some up
Would not know myself which Grade of Stainless you require. But from Phil Denton website - We manufacture our components in Grade 303 and high tensile Grade 431 stainless steel
jimmock
#13 PostAuthor: jimmock » Tue Jan 14, 2014 9:54 pm
I know many that will point you to the door, if asked this!!
Jimmock. :wnkr
z1000puddin
#14 PostAuthor: z1000puddin » Tue Jan 14, 2014 10:02 pm
Jim,
The 17-4 stainless I used is a B***D to machine - it wrecks cutting tips.
But is very very strong.
We use this materials in a all of our Umbilical sheave shafts & swivel heads.
http://www.specialtysteelsupply.com/bro ... l-data.pdf
Zed til Dead
steve bowdler
#15 PostAuthor: steve bowdler » Tue Jan 14, 2014 10:20 pm
I am sure the Alloy fork legs would be weaker than the stainless axles :roll:
Users browsing this forum: Bing [Bot], KeithZ1R and 49 guests
