z1000 mk2
- big green bus
z1000 mk2
Does anybody know what battery I can fit to a z1000mk 2 that has a bit less height. the mods I am working on required I moved the battery box up so the battery will now touch the airbox intake pipe.
You need 14 amp for the starter.
The equivalent Motobatts are smaller .
Most of the ebay listings state the L/W/H measurements so should be easy enough to find one that fits.
If you can't find one small enough there's always those Shorai Lithiums which most definitely will fit but you want to be sitting down when you see the price.
snotie1965
zed1015 wrote:You need 14 amp for the starter.
If you don`t mind me asking ? how much was the "Shorai lithium" ? and also the charger ?
snotie1965 wrote:zed1015 wrote:You need 14 amp for the starter.
Are you sitting down ?
They were £179.40 delivered from Carrot cycles in Lincoln.
Battery was £92.00 + vat etc on it's own.
Lots of different case sizes etc to choose from.
SEE HERE - http://www.carrotcycles.co.uk/index.php ... cat_id=217
- big green bus
neilbarrett
- ZedHead
LTD Project
- big green bus
