Calipers and Brake line
Wayne1960
#16 PostAuthor: Wayne1960 » Mon Jan 20, 2014 11:25 pm
Yes
Bike now finished what a joy!
#17 PostAuthor: z1bman » Mon Jan 20, 2014 11:27 pm
where did you get the metal pipes from? do the threads taper on the nut's ?
Wayne1960
#18 PostAuthor: Wayne1960 » Mon Jan 20, 2014 11:38 pm
From Zpower so should be good no the threads look just the ones in the picture.
jimmock
#19 PostAuthor: jimmock » Tue Jan 21, 2014 3:52 am
The pipe MUST be tight against the bottom of the threaded hole in the caliper.
Or it will NOT seal.
The seal is the taper of the pipe against the taper in the hole!!
If it turns it aint tight, if it aint tight, it aint gonna seal.
Jimmock. :wnkr
I hate people I don't like !
Garn 1
#20 PostAuthor: Garn 1 » Tue Jan 21, 2014 9:40 am
Wayne, I pretty sure there is a brass olive that should be in the bottom of the threaded section in the caliper. The tube illustrated should sit on this and the fitting is compressed by screwing the connection onto it.
Wayne1960
#21 PostAuthor: Wayne1960 » Tue Jan 21, 2014 9:58 am
OK all. i removed the pipe last night and took a detailed look inside the hole. The thread appears to go all the way down the bottom of the hole. i can clearly see the small hole in the middle which i guess corresponds with the pipe. There doesn't appear to be anything in the hole or protruding from it. its all nice and clear but slightly stained.
I'm at a loss only to say that looking back on the pictures i took before i stripped the pipe it would appear the hose was connected directly into the caliper and not via the metal pipe as it should.
Be really disappointing to have to result to that!
#22 PostAuthor: z1bman » Tue Jan 21, 2014 10:10 am
what type of spanner are you using to tighten the nut? an open ended spanner is no good for tightening this type of nut you need a proper spanner. try working the nut backwards & forwards a little a a time until the brake pipe is tight.
Wayne1960
#23 PostAuthor: Wayne1960 » Tue Jan 21, 2014 10:36 am
Done that last night.
Wayne1960
#24 PostAuthor: Wayne1960 » Tue Jan 21, 2014 11:50 am
just spoke to Dave from ZPower and he believes the bottom of the hole should be raised and thinks it is some kind of brass ball with a hole. I'm just wandering if these could have come out when i had the brake calipers cleaned.
Anyone else had the same problem?
jimmock
#25 PostAuthor: jimmock » Tue Jan 21, 2014 3:54 pm
Wayne1960 wrote:just spoke to Dave from ZPower and he believes the bottom of the hole should be raised and thinks it is some kind of brass ball with a hole. I'm just wandering if these could have come out when i had the brake calipers cleaned.
Jimmock. :wnkr
Wayne1960
#26 PostAuthor: Wayne1960 » Tue Jan 21, 2014 4:24 pm
Sorry Jim
Probably didn't explain myself very well.
This is what Dave said
"Had a guy ring yesterday with the same problem but it turned out the previous owner had fitted Goodridge hoses direct to the calipers using banjo bolts which when tightened up had crushed that bronze convex thing inside the caliper, BUT yours look intact???
I have just tried two pipes in new calipers here at work and they fit no problem"
So my question was what is the bronze convex thing and can it simply fall out?
i'm at a loss
wilsonsjw11
#27 PostAuthor: wilsonsjw11 » Tue Jan 21, 2014 4:37 pm
The convex thing is what you should be looking at when you look into the threaded hole and the concave end of the pipe bridge tightens down onto to form the seal, it's what I referred to as a nipple.
Regards
Steve
Wayne1960
#28 PostAuthor: Wayne1960 » Tue Jan 21, 2014 5:02 pm
Ok i'm up on what i should be looking for but all i can see in the hole is the thread at the side and the bottom and a hole in the middle. That's it.
Is this nipple thing something that can fall out? can it be replaced.
wilsonsjw11
#29 PostAuthor: wilsonsjw11 » Tue Jan 21, 2014 5:09 pm
The convex bit should be a fixed part of the caliper and is not removable.
Regards
Steve
jimmock
#30 PostAuthor: jimmock » Tue Jan 21, 2014 6:22 pm
wilsonsjw11 wrote:The convex bit should be a fixed part of the caliper and is not removable.
Regards
Steve
I would agree.
Most likey machined into the caliper threaded hole???
Jimmock. :wnkr
