Bikini Fairing replacment Cibie twin headlights wanted
Wardy
#1 PostAuthor: Wardy » Tue Jan 21, 2014 1:49 pm
Hi All.
I have a twin headlight bikini fairing on my Z with 2 Cibie 55/60w light units.
Like this. http://www.mandp.co.uk/productinfo/517931
Unfortunately the mounts that hold the bulb retainer wire (clip) in place have broken and I need to replace the whole Cibie units.
Both M&P and Skidmarxs used to supply these faringcomplete with lights and i have contacted both on a number of occasions asking where they obtain the light units, but have never had a response.
Also a good few hours has been spent searching the net for a Cibie light supplier but again without luck.
Can anybody point me in the right direction.
Thanks for your help.
Wardy
Gary Ward
Z1000R 1983 (ELR), KLE500 2006, FX400R 1983
steve bowdler
#2 PostAuthor: steve bowdler » Tue Jan 21, 2014 2:33 pm
Hi
If it is any help I will call into M&P's this week and if I see Mark ( the owner ) will ask him if not will try to get an answer from someone .
martinz1000r
#3 PostAuthor: martinz1000r » Tue Jan 21, 2014 2:48 pm
Does it have to be Cibies? The same size of light are standard fit for slabside GSXr. Quick eBay search will flush these out for you and the mountings are same.
steve bowdler
#4 PostAuthor: steve bowdler » Tue Jan 21, 2014 5:12 pm
j.b
#5 PostAuthor: j.b » Tue Jan 21, 2014 6:02 pm
oldzed
#6 PostAuthor: oldzed » Tue Jan 21, 2014 8:29 pm
Valeo now own Cibie
You could see if your local motor factors could get you them
member number 0664
Who can catch a Kawasaki?
A police helicopter
sockpuppet
#7 PostAuthor: sockpuppet » Tue Jan 21, 2014 9:16 pm
Hi
Is it a retaining wire that has 2 legs and is hinged onto a ring that has
notches in it ? -- if it is the retaining ring/clip unit is just pushed into the
hole in the back of the lamp and can be CAREFULLY levered out with a
small screwdriver (there are 3 small rectangular holes around the ring --
if you have a look you`ll see what i mean ),
If this is the case i may be able to help you -- i think i have an old one of
these fairings in the garage but i think the reflector has gone in one lamp.
Are both units broken or just one ?
Regards
Mick
Wardy
Thank you for your help
#8 PostAuthor: Wardy » Thu Jan 23, 2014 11:33 am
Hi Steve.
Yes please by all means have a conversation with M&P.
I feel it would be by far the easier solution.
Thank you.
Martinz & JB. Thanks for this info; I will look into this after hopefully hearing from Steve.
OldZed. I had found that Valeo own Cibie but still struggled to find the options the rest of your found. Doh.
Sockpuppet. The springs are fine, it’s the point at which the springs attach to the back of the reflectors that has broken – on both units so I intend to buy two new ones for peace of mind.
Lads Thanks for your prompt replies it’s very much appreciated.
Cracking Club this.
Wardy.
Gary Ward
KWACKERZ1
#9 PostAuthor: KWACKERZ1 » Thu Jan 23, 2014 4:23 pm
Harris might be worth a call they supply these with their fairings.
Also powerbronze fairings used these, but i would speak to harris
#10 PostAuthor: chrisu » Thu Jan 23, 2014 6:22 pm
i have a set of cibies off my modified Z1R. They won't be full retail but they won't be cheap either.
were on the bike for about a year until i went back to a single headlight.
pm me with an offer if interested.
marlin
#11 PostAuthor: marlin » Sat Jan 25, 2014 7:30 pm
i have a brand new one of these fairings , green with black screen , cibies , all wiring etc never fitted , if of use to anyone give me a pm , cheers marlin
Users browsing this forum: skinnyZED and 59 guests
