VM28SS Carb Help
njwmct
VM28SS Carb Help
#1 PostAuthor: njwmct » Sat Feb 08, 2014 12:16 pm
I'm just in the process of rebuilding my Mark 2 carbs.
My problem concerns the Needle jets.
I purchased 4 genuine Mikuni Jets from Allens Performance.
On replacement 3 of the jets are a nice 'push-fit' & had to be tapped lightly into place.
But one of the jets is a loose fit.
I'm not sure whether this is a problem or not, as the main jet holder / emulsion tube seems to hold the needle jet in place.
Do I need to get another jet or is this OK?
#2 PostAuthor: z1bman » Sat Feb 08, 2014 12:27 pm
unless its as loose as a prick in a shirt sleeve i would leave it as it is the emulsion tube should prevent it moving
njwmct
#3 PostAuthor: njwmct » Sat Feb 08, 2014 12:30 pm
z1bman wrote:unless its as loose as a prick in a shirt sleeve i would leave it as it is the emulsion tube should prevent it moving
The Jet will fall in / out if you turn the carb over - but once the emulsion tube is in place it doesn't seem to rattle around.
#4 PostAuthor: z1bman » Sat Feb 08, 2014 12:33 pm
it will be fine i would leave it as it is
njwmct
#5 PostAuthor: njwmct » Sat Feb 08, 2014 12:34 pm
z1bman wrote:it will be fine i would leave it as it is
Thanks for your help.
#6 PostAuthor: z1bman » Sat Feb 08, 2014 12:42 pm
as the jet is stepped it seals on this part of the jet & shouldn't cause any fuel to leak past the outer part of the jet which you say is loose
njwmct
#7 PostAuthor: njwmct » Sat Feb 08, 2014 1:25 pm
z1bman wrote:as the jet is stepped it seals on this part of the jet & shouldn't cause any fuel to leak past the outer part of the jet which you say is loose
OK - sounds good - thanks again
Users browsing this forum: Bing [Bot] and 190 guests
