Looking for a Z1a Z1b number 4 carb body (right hand outer) just the body, dont need the float bowl or top or any linkages but anything thats out there will do so long as it can br restored.
Thanks guyz.
28mm carb
surreyz90075
- Regular Poster
carb body
Hi Dave
Did you sort out the carb body? What numbers should be on it?
I have a few 28mm carb bodies and parts.
Ken
Ken
Hi Ken thanks for the offer heres the photos I have of the carb type I am after it is the right outer carb ( if you were sitting on the bike) From a Z1B.
Just the body required but I will consider anything so long as its the correct type. The numbers are pointed out and read: 217 on the left and 15 on the right side. Not sure but 51 may indicate Jan 75 I am sure someone on here will verify this but I dont know what the 217 means.
Anyway heres the pics and thanks for any help you can offer.
Cheers Dave
This is what it looks like with the bowl removed.
Cheers Dave
