steve bowdler wrote:I am sure the Alloy fork legs would be weaker than the stainless axles
Certain stainless grades will fracture "without warning".
z1000puddin wrote:Jim,
The 17-4 stainless I used is a B***D to machine - it wrecks cutting tips.
But is very very strong.
We use this materials in a all of our Umbilical sheave shafts & swivel heads.
http://www.specialtysteelsupply.com/bro ... l-data.pdf
malmojoe wrote:aren't spindles forged? As I recall from materials science, forging will be much stronger than a machined spindle, something to do with grain boundaries and granular alignment. If there is a chance of it shearing, the anti corrosion is not worth the worry it would give at speed imo. Better to feel confident in your bike.
from a web page I found just now:
Forged Bar:
Directional alignment through the forging process has been deliberately oriented in a direction requiring maximum strength. This also yields ductility and resistance to impact and fatigue.
Machined Bar:
Unidirectional grain flow has been cut when changing contour, exposing grain ends. This renders the material more liable to fatigue and more sensitive to stress corrosion cracking.
Users browsing this forum: Bing [Bot] and 185 guests
