gpz1100 ut
snotie1965
gpz1100 ut
I have just got the standard paint work back on my unitrak (tank warning light console) , how do i go about fitting the battery warning wire ? could a buy the part that goes into the battery ? and also where on the loom is the wire located,and what colour is the wire ? I do not want to strip back to much of the tidy loom to find it ?
Any help would be appreciated ,Andy ......
snotie1965
Hi Steve.
Are you well?
I thought the part number 26012-1053 from Kawasaki.com.
http://www.wemoto.com/parts/picture/hl-705500/
Any good?
Are you well?
Any good?
"Set the GRINDER on it"
Hi Gus, I am well, thank you.
This is what I got from Kawasaki.com;
https://www.kawasakiepc.com/PartInfoDet ... 27010-1177
Googling the part No. seems to support the fact that it's correct.
Hmmmmm.
I'm Jimmocked
https://www.kawasakiepc.com/PartInfoDet ... 26012-1053
I think this must be a battery with a built in sensor
I'm Jimmocked
snotie1965
That looks like it will do ? the original bit is way to much money !! otherwise i will connect up to live feed and forget about it ?Gus wrote:Hi Steve.
Are you well?
Any good?
thanks again lads for your help .....
- steve bowdler
snotie1965
Gus wrote:Hi Steve.
Are you well?
Any good?
That looks like it will do ? has anyone used this type before ? if not i will go for the original kwak one £18 seems a fairish price ?
snotie1965
Users browsing this forum: Bing [Bot] and 185 guests
