Please can you let me know
KWACKERZ1 wrote:
This is the one I would go for!!!!!
http://www.ebay.co.uk/itm/Kawasaki-Z100 ... 4861ad06b8
Its complete with cams and everything you need!
neilbarrett wrote:will all the muck in the head you carnt see weather theres any cracks between the sparkplug holes and valve seats
KWACKERZ1 wrote:This is the one I would go for!!!!!
I visited D & K Motorcycles today and had a look at the cylinder head you are interested in.
It is off a Z1000C Police bike, so although it probably has done more miles than Apollo 14, it will have been serviced precisely when required and maintained regardless of expense.
There are no cracks between the spark plug holes and the valve seats, all the fins are intact, but I did not take a selection of screws and bolts to check if the threads are ok. Surprisingly, there are no wear marks at all on the cam lobes, so perhaps it has had some new cams recently.
It does need a good clean however, but I am sure that you have plans in place for that.
The two pics below are ones I took with my camera today, I have the high resolution versions if you want me to email them to you. PM me your email address if you want them.
