Z750 L4 front and rear end upgrade
Sometime in the future I'm going to be looking to upgrade the front and rear end on a Z750L4 I have in the back garden, can anyone one suggest a complete set that would work? I have use of an engineer to do the pressing out of the steering stem and welding up etc, but wanted to know which would be a good fit, i.e. the forks would be long enough and the swinging arm would fit reasonably easy.
Any recommendations would be apreciated.
What we got here, is failure to comunicate.
z750
how far do u want to go
I picked up this lot for 100 squids but im after lower stance and handling yokes from a gs750 with zrx 400 running gear the job lot 4 pot brakes all drop's straight in and zrx1100 swing arm zrx 400 back wheel can mono shock or twin shock look around and see what u wanna dooooooo
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
- big green bus
this is 550 zephyr me old spud ..ya kna i fitted this to the bike pictured so i think id know ..well if im not on snakebite ...and yes we all know ure not 100%big green bus wrote:you may need to sleeve the swingarm pivot down I think the zephyr's have 17mm swingarm bolt and the z's is 15, but not a 100%
Gary, on the 650 frames you would need to sleeve it down, not sure about 750 frames. Though you will need a spacer both sides to stop it moving side to side. Zephyr 750 arm very alike, but has no channel down outside edge of arm,but is just smooth. also 750 arm a bit more bracing behind pivot tube, but don't think it makes any difference.
Gary, Go see Barry, he did mine. What I did was use the original swingarm bolt for the frame which will be too small for the swingarm. He made press in sleeves for the swingarm taking the i/d down to the same as the bolt.
The other option is drill out the frame either side so the bigger bolt will fit, difficult to go back if you go that way.
Users browsing this forum: No registered users and 205 guests
