wire loom
#16 PostAuthor: z1bman » Mon Mar 10, 2014 8:11 pm
ignore the wires from the left hand switch. the blue wire which comes from the main wiring harness plugs in to the blue wire ( male bullet ) from the r/h switch
the blue wire on the harness is the positive feed for the headlight
#17 PostAuthor: z1bman » Mon Mar 10, 2014 8:24 pm
have you fitted new pattern/ after market switches?
Wayne1960
#18 PostAuthor: Wayne1960 » Mon Mar 10, 2014 9:39 pm
Yes they cam with the bike all still in their wrappers.
Bike now finished what a joy!
#19 PostAuthor: z1bman » Mon Mar 10, 2014 9:47 pm
you said your l/h switch has two blue wires one with a twin female connector + the other has a single male bullet is this correct? as it should have a black wire with a twin female connector
Wayne1960
#20 PostAuthor: Wayne1960 » Mon Mar 10, 2014 11:01 pm
Sorry z
L/H has a single blue with bullet and a single black with bullet which I'm guessing goes to the horn. I have plugged the blue cable from the main loom into the blue from the switch.
The right hand has a single blue with a bullet and a blue with a twin female bullet. Nothing plugged into them at the mo!
#21 PostAuthor: z1bman » Mon Mar 10, 2014 11:09 pm
yes that is correct for the 900 a4 it was the twin blue female connector which i couldn't trace ?
Wayne1960
#22 PostAuthor: Wayne1960 » Mon Mar 10, 2014 11:13 pm
Ok so I'm sorted on the left but what are the single and twin blues for on the right?
#23 PostAuthor: z1bman » Mon Mar 10, 2014 11:32 pm
the after market switches are designed to fit the z1/a/b & the z900 a4 but the way the power from the fuse is distributed differently. so if you have a z1/a/b the r/h switch is used for power distribution & if its a z900a4 the left hand switch is used . so depending on which model you have you will have wires which do nothing
Wayne1960
#24 PostAuthor: Wayne1960 » Mon Mar 10, 2014 11:33 pm
I have a z900 a4 1976
Wayne1960
#25 PostAuthor: Wayne1960 » Tue Mar 11, 2014 6:50 am
Hi Z
I guess I'm done, thanks for your help.if anyone has a picture of the brake failure unit fixed under the coil I would appreciate it. Want to get it right!
Also one of the wires has come out of the plug. How do you get the brass bit out to reconnect. It looks simple enough.
#26 PostAuthor: z1bman » Tue Mar 11, 2014 9:40 am
the switch has a L shaped bracket & is fitted on the left hand rear nut of the left hand coil between the nut & the frame. the barb on the bracket faces the rear. the brass electrical connector has a small barb you have to press this down to release the connector
this is what the barb looks like
Wayne1960
#27 PostAuthor: Wayne1960 » Tue Mar 11, 2014 10:16 am
Z i have never seen anything like that. the 2 parts i am interested in are
28019-001 and 32060-014 of the Z900 A4 parts catologue which are on pages 88 and 89.
#28 PostAuthor: z1bman » Tue Mar 11, 2014 10:30 am
this is the switch i do not have a photo of the mounting bracket but you can see what it looks like on the parts diagram
is this the connector that has broken in the switch?
Wayne1960
#29 PostAuthor: Wayne1960 » Tue Mar 11, 2014 11:00 am
z that's great and yes that is the switch and i have the bracket which is flat l shaped.
the question is exact location.
no the connection is a 4 way connector block with female pins which one of the cables has come out. I cant get the pin out to clamp the cable back in.
#30 PostAuthor: z1bman » Tue Mar 11, 2014 8:08 pm
this picture shows the left hand coil. the outage switch is fitted on the coil mounting closest to the cable tie in this picture. remove the coil & fit the outage switch complete with its bracket between the coil mounting screw & the frame then put the nut on the other side of the frame mounting for the coil. fit the L shaped bracket to the switch exactly as it is in the picture bellow with the wiring pointing towards the carbs
