Advice appreciated
ZedHead wrote:As compo said. Try tapping the float chamber bottom with a screwdiver handle, it might clear it. What is the tank like inside?
All 4 float chamber pipes are dry.Compo1955 wrote:If fuel is coming from the float chamber overflow pipe, this indicates that the fuel level in that carb is becoming too high.
It may be that the needle valve is being held off its seat by debris or the seal between the valve and seat isn`t as good as it should be.
If it is something between the jet/seat, it might clear next time you run the motor ( it you are lucky), if not you will have to remove the float chamber and have a look.....
It's not coming out of the float chamber overflow pipe but the breather on no 2 carb.pertonpc wrote:Hi,
The tubes that go from bottom of carb float bowls are OVERFLOW not BREATHER.
Breather tube is a seperate one routed upwards ending near air box.
Need to check fuel level in float bowls - if the leaky one is higher than rest that will need adjusting.
Like compo says it is common to get a little fuel weeping sometimes.
If you have a gravity fuel tap (not vacuum) try turning off a few minutes before you stop the engine.
If persists you gotta drop the float bowl and clean or replace the float valve if it is worn.
From Mark
That might explain sooty plug on no2 and rough running when hot? Will have a look when I get home. Cheers Bud!z1bman wrote:in that case your fuel overflow pipe must be blocked if fuel is going that far up the carb body. have you looked in the air box? its probably full of fuel
Interesting that. I think the previous owner fitted new rubber pipes and has terminated all 6 around the swing arm area and just that one from carb 2 (and 1 as you rightly point out) was misplaced to be resting in the pivot dribbling fuel. Will investigate later. thanks a lot. MJpertonpc wrote:Hi Mate
If it is a carb breather pipe I don't think it should be routed to end at the swing arm pivot as you describe.
All breathers on early kwak carbs I seen are only about 20-30cm length and end up near the upper airbox area.
Also I think the breather by No. 2 serves carb 1 + 2 - should be another on tother side to serve 3 + 4. So the source could be 1 or 2 carb now.
Your pipe sounds too long or routed wrong - which might be part of the problem also.
