2 wire lucas rear light
The lucas style rear light I have only has 2 wires standard, neither are earth and it won't work. Should it get an earth when mounted to the bike? The 2 wires I have from the loom are tail and brake and light a test light. Diagram says I should have the black/yellow earth wire but it isn't there as the light was fitted when I got it. Any ideas? Bulb/fuses are A1.
z1bman wrote:jimmock wrote:Solder a wire to the bulb holder.
On the other end of the wire solder on a terminal to fit on to the lamp mounting bolt.
This way everything is inside the lamp holder assembly.
bloody hell jim a serious answer ( take note garn )![]()
Thank you Z1Bman,
Jimmock's the name, and solutions is my game!!!
Jimmock.
I hate people I don't like !
jimmock wrote:z1bman wrote:jimmock wrote:Solder a wire to the bulb holder.
Thank you Z1Bman,
Redbeard wrote:Thanks Jim, I feel honoured that it was my question you chose to answer seriously.
Yes Redbeard, after giving it great consideration I did indeed choose your question to be the ONE I answered sensibly.
Well done Redbeard!!!
Jimmock.
jimmock wrote:Redbeard wrote:Thanks Jim, I feel honoured that it was my question you chose to answer seriously.
on a serious note I will give your suggestion a whirl this weekend mate, cheers.
Users browsing this forum: No registered users and 134 guests
