z1000 side panel badges
markz9
#1 PostAuthor: markz9 » Thu Mar 20, 2014 1:57 pm
hi does any body have a spare set of metal side panels badges for a z1000a1 same style as the z900a4 badge but 1000 tried zpower not quite right dont mind if they need repainting/ refurb
cheers
mark
#2 PostAuthor: z1bman » Thu Mar 20, 2014 2:08 pm
markz9
z1000
#3 PostAuthor: markz9 » Thu Mar 20, 2014 3:48 pm
thanks for the link do you know if the german ones are metal or plastic ?? the french ones look like what the pair of plastic badges i got from zpower
#4 PostAuthor: Ginger Bear » Fri Mar 21, 2014 7:42 pm
I'm not sure Z1000 side panel badges were ever metal. Z1 900 yes, but Z1000?
# 104
#5 PostAuthor: z1bman » Fri Mar 21, 2014 7:51 pm
yes they where metal as far as i can remember
#6 PostAuthor: Ginger Bear » Fri Mar 21, 2014 7:55 pm
Thanks Paul,
I'm always happy to stand corrected......... & learn something at the same time. :)
# 104
#7 PostAuthor: z1bman » Fri Mar 21, 2014 7:59 pm
Our selection of replica badges are cast from a casting metal, harder than alloy but still slightly flexible. All metal badges are chromed or gold plated, and painted with two-pack enamels or automotive lacquers. They replicate, as closely as possible, the original factory item in size, shape, color and finish. However, due to slight shrinkage of the metal during the casting process, some badges may not exactly fit the mount points, for both screw mounted and push-in types. Many badges have been modified to take this shrinkage into account, so that they will fit easily without modification
http://www.reproductiondecals.com/defau ... .html~main
freddyz1r
#8 PostAuthor: freddyz1r » Fri Mar 21, 2014 9:42 pm
good useful link :up thanks z1bman
