Alternatives to K&N's
Magnum1
#1 PostAuthor: Magnum1 » Thu Mar 27, 2014 8:37 pm
My K&N's foul the cross member on the Harris and I've been thinking about changing to Ram Air foam filters. Can anyone offer any advice/knowledge on the subject - are they any good?
Rod
jphaynes669
#2 PostAuthor: jphaynes669 » Thu Mar 27, 2014 9:03 pm
I just fitted a set of offset ramair foam filters on my bike. Its a fair bit quieter on induction noise and seems quite responsive. I will hopefully ride it at the weekend so will let you know. I have left the set up as per the k&n, s and dont really expect any glitches.
The foam is fairly thick and at least 2 layers, fitment was good at the neck with decent clips supplied,. You can order in sets of 4 and some sets are priced reduced at the moment.
Got them direct from www.ramair-filters.co.uk
01980 635300 ....paid just under £60. :)
Jeff.H
jimmock
#3 PostAuthor: jimmock » Thu Mar 27, 2014 11:32 pm
Magnum,
I had the EXACT same problem.
I cut out the cross member.
The bike runs really nice with the new filters.
Jimmock. :wnkr
I hate people I don't like !
harrythemagnum
#4 PostAuthor: harrythemagnum » Fri Mar 28, 2014 4:40 pm
I used these Ramair twins on my ZRX, quite cheap off ebay.
http://www.ebay.co.uk/itm/RAMAIR-PERFOR ... 5aeb307565
They are only socks, so you will need some trumpet type things for them to pull over.
What a wonderful philosophy you have,
Magnum1
#5 PostAuthor: Magnum1 » Fri Mar 28, 2014 6:38 pm
jimmock wrote:Magnum,
Had to get a new hacksaw blade, but got through eventually. Thanks for the tip!
Rod
jimmock
#6 PostAuthor: jimmock » Fri Mar 28, 2014 7:15 pm
Rod
Rod,
I'm chuffed to fook I was able to help.
I take real pride in my "ability" to see solutions others cannot!
Jimmock. :wnkr
garyd
#7 PostAuthor: garyd » Sat Mar 29, 2014 6:59 am
Rod
Rod,
You guys are so ANAL....
What's wrong with a chisel and hammer :?:
Magnum1
#8 PostAuthor: Magnum1 » Sat Mar 29, 2014 10:47 am
Rod
And pragmatic - the doers of the world
Rod,
:wink: :wink: :wink:
Magnum1
#9 PostAuthor: Magnum1 » Sun Mar 30, 2014 7:32 am
jphaynes669 wrote:I just fitted a set of offset ramair foam filters on my bike. Its a fair bit quieter on induction noise and seems quite responsive. I will hopefully ride it at the weekend so will let you know. I have left the set up as per the k&n, s and dont really expect any glitches.
Be interested to know how they run Jeff.
rod
Users browsing this forum: No registered users and 205 guests
